vdc & slip problem
vdc & slip problem
Car: 03 G35 Coupe 5AT
vdc off, slip, sel lights on
goes into limp mode when those lights are on with power loss
things done:
spark plugs cleaning
TB cleaning
Oil Flush/ Filter, Air Filter
Went away for few days, now its back again
What could it be?
Also I tried to reset the ecu but the brake pedal are all hard when car is off, so how do i reset?
Don't have the car with me right now.. but I read around and could low brake fluid cause this? why would the engine loose power though?
Thanks
Edit: ok sorry I read the ecu reset instructions wrong and thought it was brake pedal when it was actually Gas! lol will try that out now..
things done:
TB cleaning
What could it be?
Thanks
what do you mean by tire systems?
Also another observation is that it starts and runs fine from a Cold start
but after 10-15mins of driving, it jerks for a second and all these lights turn on
or sometimes it may just shut off when I'm at a light and starting takes a while longer than normal + the lights turn on, restarting wont fix it, have to let it cool completely
Bump. still happening..
my observation from 1 week of driving:
from cold start, it starts up fine.. runs, has full power, etc.
after 10-15 mins of driving and getting up to normal temp. the car cuts out if I'm stopped.. or gives a sudden jerk if I'm driving & continues to go BUT the Vdc/Slip lights turn on = driving turns to crap and there's no high end power anymore, shifts bad, climbs rpm bad.. really hard to get it up to 80-100mph range
however, after the first cut off... it never cuts off after that, no matter how long I drive or how many times I shut off/start the car. but the lights are still on and drives like crap.
if it cuts out, it struggles to start.. and on start up, vdc/slip on
any thoughts on the cause?
It's really getting annoying.. I'm getting passed by ricer Hondas and I can't do anything! I used to screw any car on the road.. now I can't even pass an Altima! what the hell's happening
Just now I got owned by my friends brz, which I used to own by 3-4 car lengths just on 2nd gear.. now I can barely keep up with him, so embarrassing!
haven't had the chance to take it to dealer yet
i find it funny you think its more embarrassing than troubling your car isnt running properly. the first day my car started to act as you are describing i would stop driving it until i fully understood what the issue was. you might be doing a lot more damage to your car than you realize.
you are on consult II the dealership should be able to tell you exactly what the issue is.
but as previously stated it does sound like a cam sensor. it is however odd your vdc and slip come on when this happens since they are not connected in anyway.
by the way, has anyone had issues with their A/C blowing warm air & not cooling?
I haven't turned it on in a while but it was fine & chilled before, only thing i can think of is, I had done the battery disconnect ecu reset a couple times in the last few weeks.. could this cause climate control issues? or is the cooling gas just over
by the way, has anyone had issues with their A/C blowing warm air & not cooling? I haven't turned it on in a while but it was fine & chilled before, only thing i can think of is, I had done the battery disconnect ecu reset a couple times in the last few weeks.. could this cause climate control issues? or is the cooling gas just over
