Tire load rating???
Tire load rating???
Could any body inform me of the load rating per tire for the 03-04 g35 coupe 6mt I've been looking all over and can't seem to find it. And yes I know it's in the door jamb but I took all the stickers off except vin stickers for paint because I thought I would never need it 😫. If some one could post a pic or a reply I'd really appreciate it 😅
You must be the very first member to be concerned about load rating! Unless you and your wife (g/f) weight 600 lbs each it shouldn't be a concern. Passengers tires all have about the same rating until you get into truck tires. Your main concern when buying tires should be the wear rating, that's the UTQG! Contact www.tirerack.com they'll tell you the same thing.
Gary
Gary
Found this info for the two available OE 18" brands on the 2004 coupe. Got it on tirerack.
Michelin Pilot sport
225/45/18 = 1521 lbs
245/45/18 = 1764 lbs
Potenza RE050A
225/45/18 = 1356 lbs
245/45/18 = 1565 lbs
What brand and model tires are you running and what sizes?
From tirerack....
245/35/20 = 1323 lbs
275/30/20 = 1609 lbs.
Compared to the OEM tires
Potenza RE050A
I'd just print out the page from Tirerack on the Potenza's and present that along with the page from tirerack with your S-drives and highlight the OEM and your tires sizes and give that to the inspector.
Potenza RE050A
