OEM replacement / aftermarket headlight reviews
Old 07-23-2015, 09:44 AM
bTanz's Avatar
guys...most of us still running G35s are running into the headlight UV damage 'issue' on our OEM headlights(mine are HID).
i realize polishing them is an option but it's one im getting tired of. i'm considering some of the aftermarket OE replacement lights on the market but i'm finding very few reviews
who has direct experience, either good or bad, with any of the aftermarket headlights brands and models?
I have found 3 options so far that keep the OEM look...what else may be out there that's quality??
~ Spyder - Black Euro Headlight
~ AM Autoparts - p/n AM-3776100100
~ Artzone - black p/n E1I352D03HBK
Thanks!
Old 07-23-2015, 10:13 AM
DigitalDeviant's Avatar
I bought the AM ones for a retrofit. Only issues are the seal needs replaced by better material which you can get cheap. and cheaper plastics, so if you are backing them. do not bake over 200F or they will warp.
However, I only bad 280 shipped. Prices went up it seems.
Urbanengineer (07-24-2015)
Old 07-23-2015, 12:34 PM
bizkardi's Avatar
Wet sand your OEM lights with 800, 1000, 1500, then 2000.
Spray this over them, do 5 coats http://www.autozone.com/paint-and-bo...el/465393_0_0/
Buff out the orange peel and you'll have crystal clear head lights that will never oxidize again.
Bean_VQ35DE (08-17-2015)
Old 07-23-2015, 12:47 PM
unless you have stress cracks
Old 07-23-2015, 04:15 PM
bTanz's Avatar
hmmmmm ... have not tried this approach yet. Have i been snoozin while this became the answer or are you at the tip of the spear here. How long have you been running your lights/car post the buff-VHT-buff process without degradation??
ThX!!
Old 07-23-2015, 07:17 PM
dEnbOy.GFM's Avatar
I had a couple layers of clear coat applied to them at a body shop. I maintain them just as I do the paint and they've been spotless for the last 5 years.
Old 07-23-2015, 08:41 PM
bTanz's Avatar
dEnbOy.GFM i think i'm headed down this road ... prior to the body shop clear coat did you prep the lens with the wet sanding process??
Old 07-24-2015, 12:11 PM
dEnbOy.GFM's Avatar
I've always taken good care of them, so there wasn't any prior hazing or anything before I had the car in the shop. They probably did some amount of prep work to them, but I know I didn't. They turned out great though. My tailights are also clear coated for good measure.
Old 07-24-2015, 02:01 PM
bTanz's Avatar
guys ... you got the wheels turnin so i phoned my favorite plastic repair company ... SEM. This looks like the way to go Solaray™ UV Clearcoat (http://www.semproducts.com/refinish-...m-uv-clearcoat) now i just need to locate a UV A 70w lamp and some eye pro.
SEM claims it far better then a 2k(catalyzed/hardened) clear, which of course is better then a 1K(spray can) for long life!
Sounds like guys are having good results with all 3 options ... if i cant find a UV A lamp to borrow i'll likely go down the 1K or 2K clear coat road.
Old 08-11-2015, 06:44 PM
Jeffreybonilla5's Avatar
guys...most of us still running G35s are running into the headlight UV damage 'issue' on our OEM headlights(mine are HID). i realize polishing them is an option but it's one im getting tired of. i'm considering some of the aftermarket OE replacement lights on the market but i'm finding very few reviews who has direct experience, either good or bad, with any of the aftermarket headlights brands and models? I have found 3 options so far that keep the OEM look...what else may be out there that's quality?? ~ Spyder - Black Euro Headlight ~ AM Autoparts - p/n AM-3776100100 ~ Artzone - black p/n E1I352D03HBK Thanks!
are u intrested in tring to keep the stock look?
Old 08-11-2015, 08:35 PM
bTanz's Avatar
yes
Old 08-11-2015, 08:42 PM
yes
http://m.1aauto.com/2003-05-infiniti...=624508&y=2003 i bought these, had them on for a couple months, no problems nice and clear, worth the price and warranty, try Carid.com also just remember warranty and both sites have diffrent options and quality and design and if u need bulbs/balast after market, i got both Ddmtuning.com and Diodedynamics.com
Old 08-11-2015, 09:25 PM
bTanz's Avatar
thanks!! i'll give a look
Old 08-11-2015, 09:28 PM
no problem
Old 08-12-2015, 01:57 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Rather than wasting time and $$ the crap '03 thru '05 OE headlights upgrade to '06/'07 projectors! When I post "Different as Night & Day" that's a fact! There's no comparison with the projectors since you can see clearly at night...Gary
Quick Reply: OEM replacement / aftermarket headlight reviews
