Rough idle, car dies and will not stay running.
Old 08-27-2015, 09:35 PM
Silver tiburon's Avatar
I have an 03' G35 coupe. Today, it suddenly started suddenly running crappy.
For starters, the car will not idle on it's own. If you start it and play with the gas, you can eventually get it to run. Once it's in the upper RPM range,it will run, and seems ok. However, as soon as you let of the gas, the RPMs drop and the car will die. It will restart every time, just wont idle.
While driving, the car doesn't seem down on power. It will pull just fine at WOT, and seems to run ok as long as you're in the upper RPM range. It's not smoking, and mechanically everything seems ok.
There are NO check engine lights. There was a stored misfire code, which is to be expected seeing as the car runs like *** at idle. Otherwise the codes are clean.
Searching around didn't really yield much help. I tried all the relearn procedures here: http://www.nicoclub.com/archives/g35...-learning.html . None of them helped.
I'm looking for suggestions. I would assume if the throttle body was ****, it would throw a code. Maybe not? Any help would be greatly appreciated.
-Brett
Old 08-27-2015, 09:41 PM
hurleyguys's Avatar
well check spark plug and fuel injectors for starters. is your car stock?
Old 08-27-2015, 10:00 PM
The car is stock aside from an HKS intake and exhaust.
Old 08-27-2015, 10:38 PM
knightro g35's Avatar
Sounds like you might need to clean out the MAF (mass air flow) sensor and the throttle body.
Old 08-28-2015, 07:02 AM
VenomGT9's Avatar
How long ago was the intake and exhaust installed?
Old 08-28-2015, 12:38 PM
ScraggleRock's Avatar
Ding ding ding
Winner.
Old 08-28-2015, 01:12 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Start with the MAF and check that intake filter, HKS needs to be cleaned frequently...Gary
Old 08-28-2015, 03:25 PM
The car only has about 85k miles on it. I've had the intake and exhaust installed for probably 15k.
I removed the air filter completely and started the car to see if that did anything, and got no change. I did some research, and cleaning the MAF should be easy. That will be my next step.
For the throttle body, I'm finding conflicting information on cleaning it. A lot of people say not to, some say it's fine. Is there a good how-to or something somebody can like me to? Any info or advice on this?
The car ran perfect 2 days ago,and now runs like complete a$$. Would a bad MAF or TB not throw a code?
Old 08-28-2015, 04:49 PM
VenomGT9's Avatar
May be random but, what kind of gas did you put in your tank last?
Old 08-28-2015, 05:44 PM
Extreme Dimensions's Avatar
Sounds like the MAF or the Throttle Position
Old 08-28-2015, 09:29 PM
Ok guys. First, let me say thanks for the suggestions!
I think I figured out the problem. So, the foam filter for the HKS intake system seems to be deteriorating a bit on the inside. As a result, some little pieces of the foam got sucked into the intake, and also into the MAF. I could literally see little foam pieces inside of the MAF where the sensor wires are located:
So, I just blew the sensor out with compressed air and reinstalled it. I started the car (air filter removed) and it fired right up and seems to be running perfect. Seems like the issue is gone. I ordered a new filter element, so I can't really drive the car until it gets here. I'll report back and confirm the issue is fixed.
Thanks again for all the help, guys.
Old 08-29-2015, 11:27 AM
gary c's Avatar
Glad you figured out your issue!
HKS has major issues with quality control and never admits their products are anything but perfection! Best advice, replace the HKS intake with Stillen's CAI which comes with a large K&N cone filter...Gary
Old 09-04-2015, 07:17 PM
Installed a new filter, and cleaned the MAF with CRC mass airflow sensor cleaner. The car is running great now.
Thanks for the help, guys.
ghost_g35
08-07-2015 10:31 AM
itschuckster
07-25-2015 08:07 AM
apintojr
07-23-2015 10:52 AM
Thaaa_king
07-18-2015 05:56 PM
Quick Reply: Rough idle, car dies and will not stay running.
