maintenance this summer what should i
Im gonna spend the first half of the year ordering things i need for the g for the summer
This year i just want maintenance ,spacers,z tube detail interior and change all the leds.
Anyways what should i replace. Its a stock 03 with 120k. Manual.
Should i change any sensors to avoid probelms? Starter? Anything that usually goes wrong at 120k? I already changed the radiator, thermostat, hawk brakes and all cross drilled rotors. I need to change both front bearings and im looking into inner outter tie rods
Thanks
Thanks
What do u mean gasket if i dothe spacers? Head gasket?
Can i change valve cover gasket and not valve cover?
As far as maintenance, a complete tune up and fluid replacement is in order (if not done at 100K). Then replace any suspension or other items as needed. I'm sure your shocks are worn out at that mileage, people often wait until those are toast before replacing them not realizing that worn shocks have a big effect on handling.
A Whiteline Essentials Kit covers the major bushings that give these cars headaches.
A thorough cleaning of the throttle body will help, just remember to disconnect the battery then unplug it before you start moving the butterfly for cleaning.
I'm at 196k and this spring am looking into a suspension refresh: new ball joints, end links, shocks & mounting hats. Already have whiteline bushings due to bad compression rod. Might even replace upstream O2 sensors to keep things in top shape.
If you get it new, it will have a gasket. Used spacer runs the chance of a damaged gasket.
I dont want an uncomfortable ride from dropping it. I dont take corners hard but i do want to upgrade any parts i replace with something just a little better than stock ,even if its a bit more expensive il b happy as long as its classy and comfortable.
Are aftermarket cam position sensors ok? Or should I do eom?
I'm doing those, inner litter tie rods, cabin air filter, plugs, possibly valve cover. I'm not gonna do 02 sensors yet because them going bad will throw a code and it won't leave me stranded..
What else should I change to avoid being stuck somewhere?
I'm going to wait for shocks , with the bushings wich ones are more likely to be bad? I rather not spend hundreds on a kit, I'm going to replace as needed.
I changed my mind on performance parts for this year. I rather do a nice detail, system , and maintenance.
sales@aamcomp
Engine-Vendor
01-08-2016 12:28 PM
sales@aamcomp
Exhaust-Vendor
01-08-2016 12:27 PM
dpierce33967
Engine - Intake/Fuel
12-30-2015 05:33 PM
