Dashlights not working help!
Just bought a pioneer radio for my infiniti g35 . made a rookie mistake and hooked up the orange(illumination) and orange white(dimmer) together(i think what caused the problem) and now my dashlights, radio, tail lights and daylight lamps dont work. I did check the fuses and they were fine. Any suggestions on how to fix this?
Radio: Pioneer FH-X720BT
Harness: Scosche CNN03 Wiring Harness, Radio Replacement Module
Atenna adapter:Metra 40-NI10 Antenna Adapter
Did you find out the problem?
There are three fuse boxes in a g coupe, did you check all of them? The fuse that you are looking for is a 10A on your IPDM/ER which is hidden damn near behind your battery under a couple plastic covers. I've blown that fuse twice and all the things you described go offline. You will notice all the really expensive stuff is on there so ignorant folks won't find it and have to go to the dealer. I got your back though, if it's not that let me know and I'll look at the wiring schematic, where the real fun starts.
on
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/lt.pdf
See page LT-192
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/pg.pdf
Good luck
Telcoman
Phenomenon9
02-14-2016 01:11 AM
06G35newbie
11-26-2015 11:06 PM
