A/T check light flashes 16 times! HELP!
not an option, beside i just got it and only for 1000$ really any amount of work it needs is worth it
I'd try to drain and fill the trans. Your not going to get all of it out but put Nissan fluid back in, the same amount that you took out. I'd pull the battery cable while you do that for about 15 minutes and try again.
Low fluid, clogged filter? Check 1-2 psi.. Mine slips too and also generates a howling sound that was relieved by drain and refill of teams fluid where I discovered low fluid and replaced my filter.. The howling reduced tremendously.. Not sure if exactly pertains to your case but somethings are more simple than expected especially wit 170k plus.. But idk;p
Treewax
01-25-2016 11:32 PM
Vesperia
01-23-2016 11:04 PM
