Beeping as if I'm trying to lock the key in the car
My '07 coupe recently started beeping when I get in the car and close the door with the key inside. Once I close the door, both doors unlock and there is a fast beeping for about 3 seconds. If the key is not in the vehicle then it doesn't beep or unlock. It's behaving as if it thinks I'm trying to lock the key inside so I'm assuming this means a control module or sensor has gone bad. I searched the forum and found several threads about beeping, but none with a solution to this behavior. Anyone else experienced this?
I drove ttrank's car solo
Received 1,486 Likes
on
on
You're right, I need to check it just to be sure, but I don't think I'm likely to find the solution. Since the doors are unlocking I'm pretty sure it's a sensor malfunction.
