Smell From Hi Flow Cats
Hi G Owners,
I have a 03 G35 Coupe with basic modifications such as intake, plenum spacer, Osiris Engine Management, with a tune. My exhaust is completely stock and today I had HFC installed and it has this horrible exhaust smell that I noticed. It had the entire garage smelling that I had to let the garage door stay up to air out the smell. Is this a normal problem with getting HFC and will it go away or am I stuck with this problem. Any help would be welcome.
I drove ttrank's car solo
Received 1,486 Likes
on
If it's simple exhaust smell then yeah, but the way he's describing how "horrible" it is I'm just thinking it's something else. Bad cats do infact smell like sulfer.
Blue Dream (03-05-2017)
Gary
Now about why, but do you understand why installing HFC causes rasp? Nissan designed our exhaust systems for a specific flow rate/volume, replacing those very restrictive OE cats over whelms the system. Looking at factory cats one has to wonder how anything gets thru there. Adding HFCs is like putting 3# of dog crap in a 1# can, there's a visual!
Gary
Gary
To the OP, please research mods more before installing something. A HFC works by having larger holes in the catalyst material, so more exhaust "fumes" make it into the atmosphere. It's a normal side-effect of this mod. I'm curious what brand HFC you installed that smells so strongly. Mine smell a little, but nothing crazy, and I went with HFC over test pipes specifically due to smells (and I still care a little bit about the atmosphere).
