Driver side window problem, motor, or regulator?
Hello all!
I am about a year into my purchase with my G35 coupe 6MT. Yesterday, I was driving and noticed a weird sound when I was rolling up my window. To my surprise, it doesn't roll down anymore. I cannot hear the motor, and the window does not automatically slide down when you open the door. I am looking on eBay right now for a replacement part but I am confused as to which one I should buy? Is it the window motor, or the window regulator? Or should I get both? Any thoughts on this would be greatly appreciated. Thank you in advance!
If you don't hear the motor you probably need a new one. Can you slide the window up/down by hand? I've owned my G since 2006 and never had any regulator problems, but not so much on my Audi. I did recently replace the window motor on my G.
Sometimes slamming the door shut will shock it into working again. I was doing that for while on my G before getting a new one.
The regulator may need to be cleaned and lubed as the guide rails will get dirty over time but it's unlikely anything is actually broken in the regulator itself.
No problem.
My only tip would be to not disassemble the motor and guide rails from the regulator while it's on the car. IMO it's much easier to handle when left as one piece and removed from the car that way and transferred to a work bench for the surgery. Remove the window as shown, then undo the 10 (I think it's 10) bolts attaching the regulator to the door, pry the sealant apart, then lift up and out so the regulator arms clear the bottom of the door.
The only tricky part to getting the regulator back in, is getting the window to line up correctly since the door is frameless. If you have someone to help you that would be great. There are two sets of three access holes (the larger black circles), the upper three allow for adjustment while the window and door are both closed. You'll need a person on the outside to ensure everything is sealed while you are inside and can tighten the window into place.
