changed fuel pump and sending unit, but still having fuel gauge problems
Old 03-16-2017, 02:59 PM
g35bay's Avatar
Hello,
I have been trying to fix this problem for the last month, but have had no success after installing a new fuel pump and sending unit. It seems to be consuming gas very quickly, I have to fill up every 3 days. Could it be the cluster?
Any tips on what it could be, would be really appreciated.
Thank you.
2003 g35 coupe
Old 03-16-2017, 03:07 PM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
Are you certain it's filing up all the way? What is your gas mileage.
Old 03-16-2017, 04:17 PM
g35bay's Avatar
No I am not certain, but the only way to know if its full is once the pump clicks right? I believe its reading correctly when it fills up but just starts dropping fast after.
I am not sure, i have never tried calculating it. I am going to fill up again tomorrow and will calculate how many miles I get out of that gas tank.
Old 03-16-2017, 04:31 PM
g35bay's Avatar
I filled up half a tank (10 gallons) this week and traveled around 132 miles. so about 13.2 mpg
Old 03-16-2017, 09:32 PM
coffeysm's Avatar
It could be the cluster and there is a self test you can do. Make sure the lines aren't jacked up when you put everything back together.
Old 03-16-2017, 10:07 PM
g35bay's Avatar
okay thank you, I'll try to do that test soon,
One more question, my alternator just failed today. Is it possible to have fuel gauge issues because of a bad alternator?
Old 03-16-2017, 11:17 PM
coffeysm's Avatar
I don't think your alternator problem is related to a fuel gauge issue.
