MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Coupe V35 2003 - 07
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 05-08-2006, 12:00 AM
HID Fog Lights
Has anyone tried or been able to replace the standard lights in the stock headlight cluster with an HID bulb? I would like to do this if possible, other than installing an expensive aftermarket HID bracket set-up in the front bumper...
Any ideas? Let me know!
Thanks.
Old 05-08-2006, 12:20 AM
IvoryGT's Avatar
If you want to, you might want to get H4 based HID kit. But reliability is not all that great. Or you can get bi-xenon projectors intalled. Or go to japanparts.com and buy the front bumper covers for 400 and just buy a set of HID kit with projectors that fits in the front bumper.
Old 05-08-2006, 12:41 AM
i just got my 3000k yellow HID's put in my fog lights yesterday and let me tell you that they look amazing...ill take pics tomorrow (its raining) and ill post up the pics...
Old 05-08-2006, 02:19 PM
Quote:
I thought bi-xenon projectors came standard? I have an 06 Coupe and thats what the literature says...
But def post those pics man I want to see how those 3000k Yellows look.
Old 05-08-2006, 03:26 PM
IvoryGT's Avatar
You have bi-xenon? I don't think so, if you did it means the LOWBEAM has a moving shield, you can test by having someone else flick the high beam on and off and try to hear if the headlight makes a clicking sound. Or if the lowbeam appears to be brighter when high beam is on.
The bixenon Im refering to is the foglight/hi-beam, this allows you to retain both functionality when you change it into HIDs.
3000K would look like the Lexus yellow foglight.
Old 05-08-2006, 04:23 PM
2006 does have bi-xenon
__________________
06' G35 Black Coupe(AT, Premium, Sport)
Old 05-08-2006, 04:45 PM
Send a message via AIM to chilibowl
For the 06's, you can change your lower fog light area into HID's if you choose, whatever kelvin temperature you may like (3000K,4300K,6000K) and it will not affect your low beam or high beam since 06's have projector bi-xenons. 03-05's, the fog/high beam is combined in one reflector thru a dual filament bulb. If you change your fog light to hid, you will lose high beam functionality, and only your fogs will work.
__________________
'06 DG Coupe 6MT | INJEN CAI | 15% Llumar | VLEDS | JDM Clear Corners | TEIN 350Z S-Tech | 3000K HID Fogs | Hardwired Beltronics Pro RX65 | Batmobile G35HL1 Overlays |
Old 05-08-2006, 10:25 PM
Ok thanks a lot...good to have an 06 then - any reccomendations as to which brand and intensity I should go with? I really want a bright beam when my fogs are on - what is the stock kelvin?
Old 05-08-2006, 11:44 PM
Quote:
yeah, i want to see this, was thinking about it...
Old 06-27-2009, 11:57 PM
how to do change 06 fogs into hid can some1 help
__________________
04 Ss Coupe injen ti true dual / intake / dvinci 20" wheels / Nismo front /Jdm corners(with bump) / Grounding Kit / 06 Projectors
Old 06-28-2009, 11:02 AM
Quote:
I have hid fogs on my 06 coupe.
its . simple. just plug the + to + and then splice the h1 negative bulb (hid one) into the neg wire on the harness and you're set.
__________________
http://www.youtube.com/user/TofuProductionCinema <- Watch me, if you'd like.
Old 06-28-2009, 05:54 PM
Send a message via AIM to Cloud_35
There's more to it than that. First off, there is a cap that seals and hides away all the bulbs. To run the wiring from the ballasts, you're going to need to drill an extra hole into that cap and then seal it nicely or it could cause condensation to form in the headlight assembly.
I purchased an HID kit, forgot the brand tho, and the ground wire from the bulb was really short and I couldn't reach a good ground point. There is no real harness per se in the H1 fog light bulb. It is simply a power connector. The way the H1 bulb is designed is that it only has one connector for power and the base of the bulb is metal, which I found is actually used as a ground which uses the headlight housing itself as a contact point, so expecting to plug the ground into the negative side would not be a totally accurate statement.
These are some of the obstacles you may have to overcome. I figure I'd give you a heads up
Old 06-29-2009, 01:38 AM
right on.
I forgot to mention those important parts. i'm actually taking out my hid fogs and just going to be running some regular bulbs in there. i never use the fogs and I dont want to overpower my hid projectors with my hid fogs so.
good luck!
__________________
Old 11-01-2009, 10:24 AM
Can I just take the fog bulbs out and replace them with pair of NightHawks or the like?
Tags
bi, changing, coupe, fog, g35, h4, hid, lights, xenon
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
