She has twins, greddy twins that is...
Old 12-25-2006, 03:57 PM
ILLicit's Avatar
Originally Posted by ttrank
After seeing it out on the road I think I will try to paint the mesh black first and see how that looks.
I'd knew you'd listen to me... haha
  #197
Old 12-25-2006, 04:13 PM
MardiGrasMax's Avatar
Very jealous over here!
4.4psi at the manifold from 5.5psi wg springs is about right for pressure loss with the IC and pipe bends etc.
Not that is a big deal, Im just a freak, but it looks like you hit 8psi then around 4200 boost begins to slowly fall and by 6500 you down to 7.5psi, this is very comon. If your boost controler has rpm based gain you can get that 0.5 psi back by ramping the gain up in the upper RPMs. I actually like for the boost to climb a bit as RPMs increase to counter act the loss of VE at higher RPMs.
None the less, very very very nice sedan power!
  #198
Old 12-25-2006, 08:51 PM
dec55's Avatar
I hope it will be as sick as everyone thinks.
No idea on the 0-60, I would think in the 4's somewhere if I can hook up.
The 1/4 should be mid to low 12's on street tires but it depends on the driver, etc. I may be wrong high or low, these are just estimates.
Beautiful machine....would love to see the times that you will produce..
Congrats...
  #199
Old 12-25-2006, 10:48 PM
ttrank's Avatar
Grocery getter
Thanks again everyone for all the positive comments!
Here are the pics I took today. I am going to try and paint the mesh black to see how that looks.
  #200
Old 12-25-2006, 10:59 PM
mishap's Avatar
Wow, small world. MardiGrasMax...the legend on Maxima.org. I'm the brother of the Shadow on the forum. I did the turbos for his car and thebigsadler.
Looks like you'll have to give TTrank a run for it in the Maxima.
TTrank,
That's a beautiful icar. Can't wait to see what it runs at the track.
  #201
Old 12-25-2006, 11:05 PM
Floyds_racing's Avatar
paint the IC too! why cant you put the stock inserts back in with a little modifying?
  #202
Old 12-25-2006, 11:06 PM
Grumpy_G's Avatar
^^^dec55, I believe its beyond machine.
For the paint, may I suggest a high temp or engine paint. Semi-gloss or flat black, then throw it in the oven for about 5-10 minutes, medium temp.
It help cure the paint making it more resistant to chipping & flaking, because it contain either acrylic or ceramic resin.
BTW, what type of oil cooler are you using, pics? Where is the emblem comes from?
  #203
Old 12-25-2006, 11:13 PM
ttrank's Avatar
Grocery getter
Those are not inserts, that was all the bumper I had to cut out to fit the IC.
  #204
Old 12-25-2006, 11:15 PM
ttrank's Avatar
Grocery getter
The cooler is an upgraded power steering cooler. I am also going to get a larger oil cooler but right now my car holds 6.5 qts between the spacer and larger pan so it stays pretty cool.
As for the paint, I got some of that plastic coating in a spray can for tools, etc. It's flat black and I was going to try that with some additional clear on it.
  #205
dreamweaver's Avatar
looks HOTTTTTTTTT im not a sedan guy but that looks great... keep it looking great,,, I bet your one happy man. happy holidays..
  #206
Old 12-25-2006, 11:21 PM
ttrank's Avatar
Grocery getter
Thanks!
Yes, I am very happy every time I go for a drive. I got almost 16mpg on my 1st tank too which is a shock given how much I have been on it.
  #207
Old 12-25-2006, 11:34 PM
digital1986's Avatar
holy **** looks amazing!!!! very jealous and mad over here!!!
  #209
Old 12-26-2006, 12:32 AM
heyitzalex's Avatar
your car is amazing
  #210
Old 12-26-2006, 01:45 AM
DieselX's Avatar
Sweet pics... I bet there are really nice roads around your area! Hard for me to find some decent and with no traffic.
Quick Reply: She has twins, greddy twins that is...
