DIY Video Series
Rating: Thread Rating: 5 votes, 5.00 average.
  #166
Old 07-18-2008, 02:06 PM
bythabay's Avatar
Here's a little something extra from my power steering flush video...
  #167
Old 07-18-2008, 02:33 PM
elayman's Avatar
eugene do u think its necessary to flush all the fluids like the dealer tells you to? i've got 48k miles and tehy said i need brake, power steering, coolant, and another one i forget
  #168
Old 07-18-2008, 02:37 PM
bythabay's Avatar
it depends on a few variables. PM me and we can chat about it. Btw, don't do any of that stuff at the dealer, there are DIY vids for all these flushes.
  #169
Old 07-19-2008, 12:20 AM
bythabay's Avatar
  #170
Old 07-20-2008, 03:24 PM
Infinite1's Avatar
ARGH!!!! friggin rear passenger rotor won't come off!!!! Ok i'm done venting...
Any tips Eugene on getting this off? I've turned the parking brake adjustment all the way till it won't move any more w/o breaking my screwdriver.
By the way my rotors don't turn nearly as easily as it did in your video. Did I miss something? I don't have the e-brake set.
  #171
Old 07-21-2008, 05:00 AM
bythabay's Avatar
Make sure you turned the adjustment screw the right way... did you try tapping around the rotor hat?
  #172
Old 07-21-2008, 10:09 AM
Infinite1's Avatar
Hahahah...it's funny you mention that I did turn it the wrong way the first time and figured it out as the rotor wouldn't budge at all. I went the correct way until i couldn't turn the dial anymore. (didn't want to force it per your instructions)
I did tap on the rotor hat as well as wailed on it. I was thinking of tapping it on the back side of the rotor to maybe push it out. What do you think?
  #173
Old 07-21-2008, 10:53 AM
bythabay's Avatar
I think this is one of those cases where you should consult someone with lots of experience doing brakes
If you want to hold off on doing that, you could try some of the following:
a) spray some PB Blaster if the rotor is rusted on
b) figure out a way to use a puller on it
c) re-install lug nuts and lower the vehicle in attempt to loosen the rotor creatively.
  #174
Old 07-21-2008, 11:32 AM
Infinite1's Avatar
Yeah I think i'll take your advice on seeking professional help...At the same time i see now the importance of using the brake cleaner to clean off the rust..Hahah..
What's interesting is I don't need to replace the pads or rotor i just needed to change one of the studs on the wheel hub as it's stripped.
Thanks again Eugene for the advice. And keep the great DIY vids coming!
  #175
Old 07-21-2008, 02:45 PM
Dranom's Avatar
can you point me where i can get instructions on how to install sway bars? i have front and rear hotchkis sways and i wanna install it myself.
thanks!
Also what grease do i need for the bushings?
  #176
Old 07-24-2008, 01:02 PM
lexusk8's Avatar
Do you know what size deep socket is required to remove/install the PCV valve? I bought a new one from the dealer the other day and it seems larger than my 19mm socket (largest one in my socket set). Looks like I'll have to buy a deep socket just for this job
  #177
Old 07-24-2008, 01:04 PM
bythabay's Avatar
I can't remember exactly.. I think it was 21, 22, or 23 mm? I can try to check...
  #178
Old 07-27-2008, 12:06 AM
Cashj2002's Avatar
nice thread...
  #179
Old 07-27-2008, 05:49 PM
lexusk8's Avatar
I found out after doing the install yesterday it's a 23 mm that's needed. Weird size I know
  #180
Old 10-08-2008, 03:40 PM
marty315's Avatar
Still hoping for an AT transmission fluid video!
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: DIY Video Series
