DIY Video Series
Rating: Thread Rating: 5 votes, 5.00 average.
  #211
Old 01-07-2009, 09:38 PM
mikeee2's Avatar
Originally Posted by bythabay
for some reason the word C O C K is being converted into ****
THANKS!!!!!!!!
So the air relief and drain plug share the same O-ring? I guess it is, since you posted 1 part#. Just wanted to double check.
  #212
Old 01-07-2009, 09:51 PM
mikeee2's Avatar
DRAIN **** INF 21481-89900
approx $2.25 each + tax retail cost
Interesting...I did a search for the part# on google and found your thread.
https://g35driver.com/forums/g35-sed...oceedures.html
I thought the transmission uses the same washer as the oil drain plug. At least that's what I read from the forum.
  #213
Old 01-09-2009, 10:45 PM
bythabay's Avatar
That is correct if your transmission is an AUTOMATIC
  #214
Old 01-09-2009, 11:27 PM
mikeee2's Avatar
Yes, I have a slushbox. Been dying to get back on a clutch. With that being said, that's good I won't need to get the A/T washer. What about the differential washer?
  #215
Old 01-09-2009, 11:35 PM
bythabay's Avatar
Perhaps you should post your question in a different thread... but to answer, you will need to washers for the differential (one for the fill plug and one for the drain plug).
The ones Toyota uses are the same, and they are about half the price.. , just an FYI.
  #216
Old 01-21-2009, 09:48 PM
bythabay's Avatar
  #217
Old 01-21-2009, 10:12 PM
mikeee2's Avatar
Just watched your video. THANKS A MILLION. I will be doing that once the weather warms up. I'll probably skip that extra step where you let it drain another 2.5 quart. Seems a bit risky if I am doing it by myself. I like that idea of how you mark that white bottle with the quart #'s. Hmmm...I've been trying to look for a clear container like that (or shorter) but have yet to find it at local stores like Target / Walmart.
  #218
Old 01-21-2009, 10:44 PM
bythabay's Avatar
The capacity of the system is about 11qts, so if you don't do the additional 2.5 , you are really going to have a minimal impact. I would recommend at least 6qts for a basic service and 12+ for a flush.
  #219
Old 01-21-2009, 11:16 PM
mikeee2's Avatar
I was thinking if I were to just drain the 3.5 quart that I would repeat it again maybe in 6 months or 12 months. I don't drive that much. I only put in about 5k to 6k miles a year. Not that I don't want to do it like your DIY, just that I don't trust myself. I am a super newbie when it comes to DIY.
  #220
Old 02-01-2009, 01:57 AM
bythabay's Avatar
Just did a spring install on an 06X Sedan.. video coming soon
  #221
Old 02-04-2009, 10:08 AM
wrems77's Avatar
Any headlight removal/replacement vids coming soon?
  #222
Old 02-04-2009, 02:49 PM
blAk mAx's Avatar
its easy, look up front bumper removal
  #223
Old 02-04-2009, 03:03 PM
G35Papa's Avatar
  #224
Old 02-27-2009, 11:35 PM
JAYY-G35's Avatar
any DIY on how to remove exterior door handle ?
  #225
Old 03-03-2009, 10:40 PM
bythabay's Avatar
I don't have one at the moment... I'm still stalling on the spring install DIY. I'm not sure we did it in the best way.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: DIY Video Series
