DIY Video Series
#301
no your not an idiot and i thank you 4 the cabin video, so simple when U know how 3 do it keep up the good work thanx
#302
Swapping in a BBK onto our 09 fx awd - made this video in the process on how I took out the hub assemblies:
Wheel hub/bearing removal
#306
Are you asking about the parking brakes shoes video? If so, then it also applies to all coupes and sedans - the design of the mechanism is the same for all years and models.
#307
#308
#309
compression rods replacement and steering rack replacement
Steering rack replacement procedure
Compression rods replacement procedure
JaE35 (01-05-2013)
#310
Headlight bulb replacement and lower engine oil pan gasket replacement.
HID Bulb Replacement (Headlight Bulb Replacement)
Lower engine oil pan gasket replacement.
JaE35 (01-05-2013)
#314
There is one for an '03 coupe, the procedure should be very similar. Wheel speed sensor removal is really easy, just one screw to remove, then wipe down sensor.
#315
