MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Sedan V35 2003-06
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #46
Old 01-10-2008, 03:19 PM
Awesome!
Like everyone has mentioned this thread is AWESOME!!!
EVERY forum needs a sticky like this...
People have tried to (other forums) but keep it to like "wheels" or "suspension" and then after a while is gets diluted with replies. So everyone is lost.
I love that you have sections reserved, and keep ALL the information on top and UPDATED (the key)....
GREAT WORK!!!
__________________
2004 G35 Sedan | 2007 350Z (SOLD) | 2006 C6 Coupe
  #47
Old 01-10-2008, 03:30 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Thank you
This should help out a lot of people. I have spent sooooo much time on here and working on my car over the last two years it feels good to download what I know.
Maybe over time I'll write up some more detailed FAQ and DIY stuff for custom mods I've done. The problem is I don't have a lot of pictures so it ends up being 5,000 words!
__________________
ONE FUN SEDAN!! MY CAR (LINK)
Detailed Image | Greddy Twin Turbo & Built Motor by UMS Tuning = 649whp/651wtq | Rotora (12/4pot) | IForged | Quad Projector Retro | 1-off Dual 3", Dual Muffler Turbo-back Exhaust by Nichols AutoFab | NITTO | SPARCO |
  #48
Old 01-10-2008, 03:33 PM
Send a message via AIM to RADIOGUY21
maybe add to the FAQ about that mysterious spring/crunching sound at 7MPH after starting your car, (the ABS self test sound), if noone has said anything or it hasnt been added yet.
__________________
2005 G35 Sedan 5AT | Black Obsidian/Charcoal | Premium B + Navigation | Sport Package | Z tube + K&N | Z front/G35c rear springs | Stillen Sways
  #49
Old 01-10-2008, 03:40 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Quote:
Ok will do.
__________________
  #50
Old 01-10-2008, 04:02 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Ohh I forgot about camber kits! I'm shocked no one caught that before I did.
__________________
  #51
Old 01-10-2008, 04:53 PM
Sway bars?
Maybe add if 2wd sway bars will fit on the x?
Also, can you take apart the headlights? I heard that they are vacuumed and it will mess them up.
__________________
Blacked out X
  #52
Old 01-10-2008, 05:03 PM
OCG35's Avatar
Is that the new G39?
2004 Infiniti G35
lots of people have taken the headlights apart and I haven't heard of problems yet... I hope there are no probs because mine are being taken apart and painted this week... tail lights on the other hand can not be taken apart (no has that I know of)... whether or not they can be wired a certain way is yet to be determined (ehheemmm - Tim )
__________________
Link to "My Garage" for info about the car
  #53
Old 01-10-2008, 05:22 PM
got a couple other FAQs... why does the front end of my car make creeking noises at low speeds going over driveways/speed bumps etc.?
A. Check the compression rods which are known to go bad and can be replaced under warranty from dealer.
Q. Why does my rear windows make a popping/ticking noise over bumps and on accleration when they are rolled all the way up?
A. Because the window regulator bolts are too long and should be replaced with the shorter ones specified in the TSB ITB05-034. Can be replaced under warranty as well.
__________________
  #54
Old 01-10-2008, 07:29 PM
Christian's Avatar
Former G Driver
Great work Tim! This should make your job a lot easier in the sedan section.
  #55
Old 01-10-2008, 08:14 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Will they? I didn't think so (not the fronts at least).
I already say you can open them up and paint them so I think this is covered.
__________________
  #56
Old 01-10-2008, 08:16 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Thanks,
I'll get these in right now
__________________
  #57
Old 01-11-2008, 02:29 AM
The fronts wont fit on a awd, but it pretty thick bar itself. The rears are all the same so no problems there.
Also the awd might be getting coilovers hopefully soon. I will let you know that when it happens so you can edit it.
__________________
Redlude97- I still don't know what lumpia is
Mixturepinoy- It's an eggroll
Redlude97- Why not call it eggroll?!
Mixturepinoy- What the hell is pho? it's just soup, why not just call it soup??
  #58
Old 01-11-2008, 02:30 AM
Also I might add. Staggered on awd is not recommended, but there are a few that have been running without the fuse pulled and not have had any problems.
__________________
  #59
Old 01-12-2008, 12:10 AM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Quote:
I had this in there before. Should I change it?
(*Caution - it is not good for the AWD system in the X model sedan to run staggered wheels unless you remove the AWD fuse)
__________________
  #60
Old 01-12-2008, 12:38 AM
You could add that a few guys dont have the fuse pulled. But yours work. lol
__________________
Tags
2003, 2004, 2005, 350z, 35psi, beam, bushings, g35, g35x, infiniti, inop, itb05034, low, polyurethane, pressure, recommended, tire, touring, tsb
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
