MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Sedan V35 2003-06
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #61
Old 01-12-2008, 02:12 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
I'm not sure it's a good idea to say you can do it with the fuse pulled or not. Seems like if there was a problem people could come back on us.
__________________
ONE FUN SEDAN!! MY CAR (LINK)
Detailed Image | Greddy Twin Turbo & Built Motor by UMS Tuning = 649whp/651wtq | Rotora (12/4pot) | IForged | Quad Projector Retro | 1-off Dual 3", Dual Muffler Turbo-back Exhaust by Nichols AutoFab | NITTO | SPARCO |
  #62
Old 01-12-2008, 03:47 PM
Good point. Please disregard what I said then. LOL
__________________
Redlude97- I still don't know what lumpia is
Mixturepinoy- It's an eggroll
Redlude97- Why not call it eggroll?!
Mixturepinoy- What the hell is pho? it's just soup, why not just call it soup??
  #63
Old 01-12-2008, 04:10 PM
lexusk8's Avatar
Support your local G
Send a message via AIM to lexusk8 Send a message via Yahoo to lexusk8
Definitely not a good idea running staggered in the AWD sedan. A friend of mine had a '04 G35X with 19" staggered setup, and not too long afterwards his front tires started feathering pretty badly, thus making the car unsafe to drive. He then traded his X for the coupe, seemingly a worthwhile trade to me
__________________
03.5 Brilliant Silver 5AT sedan
Always Maintained by Detailed Image
  #64
Old 01-13-2008, 03:17 AM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
He went to the dark side!
__________________
  #65
Old 01-13-2008, 10:03 PM
Great job TTrank on the FAQ sticky i wish i had this avaliable to me so i didnt seem like that much of a noob.
one thing that might be good to have here for reference would be the interior lighting questions.....IE which interior bulbs fit which year O RLY started a great sticky in the interior lighting section but only the coupe was covered no sedan
Keep Up The Good Work
__________________
2006 BO Sedan | Sport Suspension Package | Motordyne 1/2" Plenum Spacer | JWT Popcharger w/Z Tube | 20% Tint | Clear Corners | L. E. D. S Everywhere |
  #66
Old 01-14-2008, 02:41 AM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Thanks, I'll make sure and add that too. Won't be until tomorrow.
__________________
  #67
Old 01-16-2008, 06:50 AM
dofu's Avatar
Just a bit of reference for the 05 non Brembos... we share the same brake rotors as the FX35, not the older sedans. Why I bring this up is because at times, it may be easier to just order rotors for a FX35 than it is to order rotors for your G35 sedan. The rookie behind the counter may mess up your order and give you the wrong parts, making a simple rotor change that much more work... Feel free to check the parts numbers.
And for those interested, the Z mid-pipe will work too, but like for coupes, it needs to be extended.
Any AWD car needs all four wheels to be the same. Unlike FWD or RWD, when you replace tires, it is ideal to replace them 4 at a time, and tread pattern from front to back matters for optimal performance too.
__________________
'05 Black Obsidian G35 6MT Sedan - slightly modded with a mild drop and cat back exhaust
  #68
Old 01-16-2008, 01:02 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Good to know on the brakes. That is the first I have heard of that one. I'll make some updates tonight.
__________________
  #69
Old 02-22-2008, 07:56 AM
Excellent info, hey one quick question. Can I use 05 oem g35 coupe springs on the Sedan? thanks
  #70
Old 02-22-2008, 01:54 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Yes they will lower your car ~0.5". I believe that answer is in the suspension one already.
__________________
  #71
Old 02-22-2008, 02:04 PM
Quote:
Not worth the .5" drop IMO.
__________________
05 Diamond Graphite 6MT sedan/Coupe 19" wheels/Eibach springs/trunk lip spoiler
  #72
Old 02-22-2008, 09:52 PM
dofu's Avatar
Quote:
Originally Posted by ttrank
Bracing Bars (ie GT Spec)
The GT Spec front and rear bars will fit the sedan. The mid-4-pt brace will not.
Front and rear tie bars and rear lateral bar will fit with the stock sedan exhaust. The rear lateral bar may not work with some aftermarket exhausts.
__________________
  #73
Old 02-22-2008, 10:33 PM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Forgot about that one.
__________________
  #74
Old 03-06-2008, 03:55 AM
hey what about a 350z/g35 coupe aftermarket header, down pipe and y pipe to fit a sedan RWD and AWD
__________________
2004 G35x Sedan.....SOLD....NEw Whip 09 Honda Accord EX-L Coupe Crystal Black pearl "PROJECT MUGEN".______If its not scraping, its not low enough..If your car still has 2 fingers or more of wheel gap, dont bother posting a "my car is soooo slammed" thread...
  #75
Old 03-11-2008, 04:46 PM
Jeff92se's Avatar
http://g35driver.com/forums/showpost...7&postcount=16
Correct the rear brembo brake rotor size please.
Rear: 12.68” x 0.87” Vented disc, 2 caliper pistons
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash
Tags
2003, 2004, 2005, 350z, 35psi, beam, bushings, g35, g35x, infiniti, inop, itb05034, low, polyurethane, pressure, recommended, tire, touring, tsb
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
