Weight Reduction Index
#47
I took out sound deadening from just the trunk area, the big patch and small patch on the passenger side. This was 15lbs.
I removed all seat belts and seat belt hardware this was over 40lbs all together.
You can go widebody and remove some of your rear quarters and replacing all your panels with fiberglass like I did Never weighed that.
Herbbie Hablib (04-11-2017)
#49
No kidding. Stupidest thing I've ever heard just to save 40lbs in a car. It's his own life though, hopefully he won't kill someone else when he becomes a projectile thru the windshield.
#51
Don't take weight reduction lightly. 100 lbs is .1 in the 1/4 mile. I have a 95 Maxima I have reduced from 3100 to 2500 lbs. It runs 12.3 N/A and 10.85 @ 125 with a 150 shot and a 1.58 60'.
Next year I am planning on getting an 05 G35 sedan so we will see how much I can reduce it. The class I am planning on racing requires 11.99 and quicker. Hoping to do it with a small shot, I was able to get the Max to run 10.98 on a 75 shot.
I do have a G35 currently but its my wife's car and she don't let me play with it.
#52
#53
#54
#55
#56
I remember years ago when Sport Compact Car was trying to build up a 150 mph CRX they did back to back dyno tests with the original wheels vs lighter wheels. Showed consistent gains of 5-7 hp throughout the rpm range. Not that the engine actually made more power of course but the lighter wheels took less power from the engine to accelerate.
#57
On the motorcycles I see at the local dyno here in town, everyone seems to go aluminum with the drive sprockets and with a lightweight low friction chain and lightweight magnesium wheels. OEM is steel (longevity).
This allows the RPM's to climb faster.
It may not truly "increase engine output" but the lightweight drive makes the RPM's climb faster and the front wheel come off the ground faster. Always feels great on the butt dyno.
Parasitic losses are reduced and the wheel hp would be closer to hp at the crank!
Scottwax (03-23-2017)
#58
#59
I put in a DSS carbon driveshaft. Nice weight drop with that. Coupe model is the same as a sedan. Ditching the 2 front seats is key, ive eliminated the driverside for now replaced with a bride euroster. I think im gonna swap that to the pax side for a Stradia on the drivers side for a but more hold.
#60
I drove ttrank's car solo
Received 1,486 Likes
on
I'm not posting this just to answer the OP's question but it's a good read if anyone here hasn't read through ttrank's build. By far my favorite car ever on this forum and bonus, I had the good fortune of driving it a few years ago. Beast is all that comes to mind to describe the experience.
https://g35driver.com/forums/g35-sed...ddy-twins.html
