Squealing Belt??????????????????
Old 12-23-2008, 01:11 AM
AARONHL's Avatar
I have another strange problem with my car that might be related to the heat problem. I've noticed this as the weather has gotten cooler. Never had this problem in warm weather.
When I start my car after it's been sitting in the cold for about 2 hours, I hear a high pitched squealing noise coming from the engine bay. It will stop as after about 30 seconds as I drive away. It also squeals for a couple seconds after I come to a stop sign and accelerate in 1st gear. Seems like it is a frozen pulley or a warn out belt, but I just replaced both belts a couple thousand miles ago. I smell something that smells like burning rubber, without doing burn-outs, after the car has been driven a little while.
Any thoughts on what the problem could be? Maybe something is wrong with the drive belt/pulley system causing my HVAC to malfunction?
Thanks,
Aaron
Old 12-23-2008, 02:29 AM
KevcoG35's Avatar
I'm really sorry, I don't have anything constuctive to say on the matter. Just wanted to say damn that must be embarrasing. Especially on a high end car like ours, I always see chevy cavaliers and lebaron's with squealing belts, never a g35. Hope you get it fixed soon or tint the front windows a lil more!
Old 12-23-2008, 02:52 AM
BBreaks's Avatar
Old 12-23-2008, 12:23 PM
AARONHL's Avatar
I know, it started happening two or three weeks ago, but yesterday it was happening regularly. It is embarrassing and since I'm a perfectionist I cannot tolerate it!
Thanks for the link, I'm going to look into it...
Old 12-23-2008, 08:04 PM
azzkikr's Avatar
inspect your belts. This happened to me as you have describe exactly and it turn out to be a slightly cracked drive belt. Replaced it and its now room room perfectly. And i smell burnt rubber too when i push my car really hard or im doing 100+. Again i think the drive belt is the cause of the burn rubber smell. I recommend you inspect your belt for cracklines even if it's just a few thousand miles new. I replace my belt like 5or6 months ago, a good 2000 miles and it has squeak yet. But the crack belt was the cause for the squeaking when igniting the car.
Old 12-24-2008, 02:16 AM
jack_burton's Avatar
just tighten the belt, that's all it needs trust me. I had the same problem even after they replaced my belts. the noob tech didn't tighten the pulley well enough
Old 12-24-2008, 03:03 AM
g35freak86's Avatar
and how do I go about tightening the belts? Can I do it from under the hood or do I need to get under the car and do it from there?
Old 12-24-2008, 03:36 AM
You need to get under the car to get the right amount of torque. If you take it to a local shop they'll do it for like 20 bucks. If not there is a DIY video someplace i think
Old 12-24-2008, 04:01 AM
g whip's Avatar
Tighten ur pulleys thats all it is
Old 12-24-2008, 11:19 AM
g35freak86's Avatar
nah I will do this myself. no way I'm paying someone to tighten a botl on my car lol.
The only bolts I need to tigten are the one that is face straight down towards the ground next to the oil pan???? or are there others
Old 12-24-2008, 01:20 PM
AARONHL's Avatar
There are two tensioners, one for the A/C belt and one for the drive belt. The one closest to the oil pan is for the drive belt.
I will tighten the belts more, but I'm afraid I will make them too tight. Is it even possible to cause damage if they are too tight? I don't have a belt measurement tool.
Old 12-24-2008, 01:23 PM
Tollboothwilley's Avatar
I had this for a while, and replaced my belts. Shortly after replacing the belts I had my AC idler pulley go out.
The squeeling you are getting is just from being not tight enough.
Old 12-24-2008, 01:50 PM
g35freak86's Avatar
I just tightened the pulley where the bolt comes right down next to the oil pan. Didn't have a measurment tool, but I did a couple good turns of the bolt (next to the oil pan). Didn't stop squeeling at all. I didn't want to overtighten the belt. It seems the skinnier belt (the one behind the fatter one) is the one making the noise. Not sure if I need to tighten more or what. However, I am just going to hit up the dealer and get new belts put on. I don't want to overtighten or cause any damage.
Old 12-24-2008, 04:44 PM
AARONHL's Avatar
That's what I'm thinking...SO COLD outside to look at anything!
Old 12-24-2008, 04:48 PM
1SlowSedan's Avatar
hahaha!! put on 3 sweaters!
Quick Reply: Squealing Belt??????????????????
