AC problem blowing hot air HELP!!
are you talking about this piece?
Received 2,456 Likes
on
Coupe 6MT Premium RAS
on
Take it down to an auto AC shop and have them pump it up with nitrogen and find the leak, fix the leak, recharge the system. If your system is completely empty DO NOT just use bottles of AC PRO or other recharge cans, you get a really bad mix of refrigerant and oil and most of them have stopleak which is really bad for the rest of the system. Using that crap in large volumes is a guaranteed way to cook your compressor within a few years.
If this is just a disposable vehicle that you're getting rid of soon then I guess it wouldn't matter and you can limp through a couple years though.
Nothing wrong with using AC PRO to top a system off yearly if you're only down a few psi.
on
on
It just means the compressor is not cycling on, some vehicles the low pressure switch will 100% prevent engagement, some vehicles it will engage and immediately disengage. You can unplug the compressor harness and (carefully) test for voltage to see if it's even getting power.
There is also an AC relay inside the IPDM, if you remove the cover and put your finger on it you should feel the vibration from the contact opening and closing while someone operates the AC on/off with the engine running. If the contact isn't operating test it to make sure it's not broken.
There is also a master fuse for the AC located in the fusible link directly attached to the battery. You can visibly inspect it, there are viewing windows for the fuses. Also a fuse in the IPDM I believe for the control side.
on
On second glance, low pressure should prevent the compressor from turning on AT ALL. You're probably just low on refrigerant and need to get it inspected and fixed.
EDIT: Usually you can tell where it's leaking from because when it leaks out the oil comes out as a VERY fine mist that sticks to the pipes or components so you end up with a compressor line that's completely covered in dirt that sticks to the oil tracks.
I'll chk things out but if it seems 2 complicated or ill break sumpn I'll b @ a shop... Lol
Can we sell things on here? I'm new so I have no clue.
Greg Huston
09-25-2016 11:36 PM
baker2795
09-02-2015 06:00 PM
