Blown Transmission - 2006
Old 03-27-2017, 03:45 AM
StockDC2's Avatar
Hello, I have a 2006 Sedan and just got word from the dealership that my automatic transmission is blown (no reverse and metal shavings in the oil). They want $5K+ for parts and labor which is insane. Given that I do this myself, I have seen transmissions for $500 on eBay. I will be calling local junkyards in hopes of finding one close to me but if I can't source one, would buying one from eBay be fine? If so, do earlier model transmissions from both G35s and 350Zs (2003 - 2005) work?
Last but not least, I did an engine swap in my Integra back when I was in highschool and have since not done anything with cars. I realize that replacing a transmission is up there in terms of difficulty but is it something that one can do with a little bit of common sense? I've tried searching for guides to get an idea of the work required but have come up short.
If you guys have any feedback/suggestions, it would be greatly appreciated.
Old 03-27-2017, 07:08 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Download a FSM from this link. http://psedog.com/cars/fsm/g35/ It'll have the transmission replacement procedure. Not sure what other transmissions would be compatible but I would think any from the 04-06 sedans, 04-07 coupes and 04-07 350's would be potential matches. Hopefully someone with more knowledge will chime in.
Old 03-27-2017, 06:27 PM
StockDC2's Avatar
Thanks for the prompt reply and for the FSM.
After calling an independent transmission dealer, I have one additional question. Is this a drop in procedure or does the TCM need to be reprogrammed?
Old 03-28-2017, 01:37 AM
Scottwax's Avatar
6 speed G35 sedan
RWD transmissions aren't particularly hard to replace. Would highly suggest you replace the seals on the one you put in and consider a shift kit as well. No idea if there is a higher stall torque converter option for a G35.
Old 03-28-2017, 02:58 AM
Blue Dream's Avatar
Not sure the TCM would need to be reprogrammed but I bet the FSM talks about it.
Old 03-28-2017, 03:14 PM
Mustang5L5's Avatar
RWD trans swaps are pretty straightforward. Do yourself a favor and rent a trans floor jack (or check CL for one as tools like this frequently pop up when guys use them one time) and h ave a buddy
