Car having a hard time turning over when starting.
+1
The CEL pretty much will tell you what's wrong. Go to AZ, ask them for their code reader (they will ask for license as a deposit) go out to parking lot and scan the codes.
Then come back here and tell us what came up.
Much better than blindly throwing $$$ at the problem.
After I replaced my battery, my starter motor spun faster, but still didn't kick over. Turns out that my cam position sensor was starting to go out. I replaced it and the car started smoothly again.
Keep in mind that there's probably about 50 reasons as to why you're having this issue; this was just my experience lately.
I am experiencing the same problem too, it usually happened when I tried starting the car after I let it sit for like more than 10hrs or overnight. The starter cranks but the engine wouldnt fire up, it usually fired up after a minute or two trying to crank it.
Could it be the battery? I mean all my accessories work fine and theres no signs of power shortage.
Starter has nothing to do with actually starting the engine...it just spins it. So if the engine turns over at the same speed...it's fine.
Not firing up right away can be many things. First thing I usually say ismwhen was last time routine maintainece was done? Could be anything frommbad plugs, to a dirty idle air controller unit
Takes a 4 cranks to start
Having the same issue. Car takes about 4-5 cranks to start and im not sure why. Have a 04g35 120k miles. CEL is ine, SLIP light on and VDC off light is on. Just had the battery alternator checked and all is good. Any ideas what the issue may be? Cam or crank sensors?
kenthung
07-21-2015 05:56 AM
