Car having a hard time turning over when starting.
Old 11-29-2009, 11:45 PM
mpspeer's Avatar
Patrick
Some times (About 50%+) when I attempt to start my car it seems to have a pretty hard time turning over. I am wondering what the cause of this may be?
Another note, it has never not started, I have always go it to start, sometimes it just goes through the motions for a second or two.
Anythoughts? I thought it may be because I could be running lean it that is possible? other than that what do you all think?
Old 11-29-2009, 11:53 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Have you replaced the battery yet? Might want to get it tested to see if it's holding a full charge. Sounds like what my 05 started doing after about 3 years. Just needed a new battery.
-GP-
Old 11-30-2009, 01:26 PM
mpspeer's Avatar
Patrick
I have. I think I have actually replaced the battery twice (maybe once), and the negative battery cord once.
zach57x (12-06-2016)
Old 11-30-2009, 01:32 PM
lilindienplaya's Avatar
do mean its hard to start as in the starter has a hard time initially getting the starter to turn over or that it just takes longer to get the car started
Old 11-30-2009, 01:57 PM
itgogitrev's Avatar
After I replaced my battery, my starter motor spun faster, but still didn't kick over. Turns out that my cam position sensor was starting to go out. I replaced it and the car started smoothly again.
Keep in mind that there's probably about 50 reasons as to why you're having this issue; this was just my experience lately.
Old 11-30-2009, 01:59 PM
ttrank's Avatar
Grocery getter
Sounds like battery to me. Also make sure your terminals are clean.
Old 11-30-2009, 02:06 PM
Tollboothwilley's Avatar
How many miles on your car?
Battery is likely the culprit, also could have some bad spark plugs if they haven't been changed yet.
Old 11-30-2009, 06:08 PM
Mustang5L5's Avatar
Need some clarification on what happens....
does the starter barely turn the engine over??
Or does the starter engage like normal, but the engine doesn't "fire" up right away?
1st is battery, but 2nd could be other issues
Old 11-30-2009, 11:09 PM
mpspeer's Avatar
Patrick
thanks for the responses, let me help clarify.
- The spark plugs are new
-Car has about 106,000miles
- It sounds like the starter engages normally, but the engine doesnt "Fire" up right away (Mustang5L5)
-it goes through its pre-start reving or whatever then turns on after about 3-4 seconds of this (Which is pretty long I would think).
Old 11-30-2009, 11:21 PM
Mustang5L5's Avatar
May i ask what makes you think you are running lean? You said so in your first post. Fuel could be a cause of delayed starting.
COuld also be spark due to incorrect plugs, in correct gap, worn plugs, etc. Did it start after changing your plugs?
Have you run the codes just for ****s and giggles to see if anything popped up?
There could be many causes of this.
Old 11-30-2009, 11:55 PM
Matzo Ball's Avatar
either battery, dirty terminals or plugs.
Old 12-01-2009, 12:16 AM
Jeff92se's Avatar
Red Card Crew
Could be a old crank angle sensor?
Old 12-01-2009, 02:19 AM
maliy06's Avatar
do you turn on ignition and wait a few seconds before the fuel pump stops pumping?? or do you just start it right away,
cause i always put in a key, turn on ignition to acc, wait until the fuel pump stops pumping and then i start it, and never had any problems with any of my G's in the past, I Had 4 G's so far and all of them started normal,
only one of my G's had a bad TB it used to choke on the road, but i changed it and never had any problems,
Old 12-02-2009, 05:18 PM
YourKuh's Avatar
...i just replaced BOTH of the cam sensors angled and straight .... ran fine for one night for about 40 minutes ... next day go to start it and ... the same symptoms as before as if the sensors whent out again.. has a hard time starting up.. but finially does..
Q: would old/bad spark plugs cause the CEL to come on (or VCD/ SLIP light)
please help...
tired of running back and forth from autozone and buying parts.
Old 12-02-2009, 05:33 PM
Jeff92se's Avatar
Red Card Crew
If you cel is on, you need to see what code is causing that.
Quick Reply: Car having a hard time turning over when starting.
