service engine soon light...help!!
on
so today was on the freeway for abt 35 min drive and wen i exit the service engine soon light turned on then parked for about 30min never happened to me then turned on and still on got back on freeway 5 min. later turned off..when i exit again was drive on street couple of min. and turned back on..disconnected the negative from battery for about 30min and since then just got back home about 45min drive and hasnt turned on since...what could it be???has me thinking..85,000 miles on the G
more than likely you have a "Small Evap Leak"
nothing serious just make sure you closed the gas cap right. (click it a few times to be sure)
on
on
when it came on lst time just popped on no blinking then turned off and wen turned on just popped out no blinking at all..ya im gng to check liquids in the morning ill let it sit over night so can get oil level right because hate that dip stick...
on
i would do thanx for the advise... im going to take off in a bit just checked water its good oil missing about half a quart stop by auto zone and buy a quart and put half...hopefully stays off..if it doesnt turn back on u think i should still worry?
I've never heard of any SES lights being triggered by having low fluids. If it happens again, go to autozone and have the codes read by an ODBII reader like someone said earlier.
