What oil filters do you guys use?
#31
i have an 03 sedan ..
i use the mobil 1 filter but i buy the filter made for the "M" .. its a larger filter..
i believe the mobil1 part number for g35 is m1-108 and the one i buy is the m1-110 ..
the m1-110 filter is larger and a direct fit for our g35's
ive been using this filter for roughly 6 oil changes now with no issues ..
hope this helps ..
p.s. i got this info from a thread somewhere in here on the forums .that goes further into detail as to why this filter works just as good if not better..
hope this helps ..
#32
So, as a way for me to monitor my consumption, i change my oil frequently. I use Castrol GTX conventional since it's so frequent. The consumption is consistent so 3500 puts me 1 quart down. I usually add 1/2 a quart at 1500 miles to allow me to only be 1/2 quart down at my oil change time.
3500 miles is less than a month of driving for me.
I never go to the max recommended oil change interval simply because that's a long time to go without checking status of the most important fluid in the car. I'd hate to drive 10K miles (a year for some people) and discover i had a minor oil leak that wend unnoticed and now have lost 1/2 my oil capacity over the course of the oil change interval.
#33
#34
I do 3500 miles religiously. My motor consumes oil, but not enough to be replaced under the TSB. It's also an AT.
The car seemed to burn less Mobil 1 than the other oils. Yes, I know synthetic burns clear, but the smell of burnt oil wasn't immediately noticeable like it was on dino.
My G is starting to burn oil as well. It goes through just under 3/4 of a quart every 3,000 miles. Which, IMO, isn't bad for 233,000 miles. I just check my oil at the 1,500 mile marker, and top off as necessary.
I'm like you, though. I put anywhere between 20-30,000 miles on my car a year. So going 10,000 an oil change would seem incredibly stupid to me...
#39
Ouch.. that jab hurt. There is research that suggests that I am not doing irreperable damage to my engine by going 10K on Mobile1. The fact that we burn about a quart every 3500 miles actually helps since we top off and introduce fresh oil. I'm not saying you are wrong in changing oil more often. In fact I agree that the more often the better. I just disagree that I am incredibly stupid for going 10k and topping off when necessary. Instead I think it's totally fine in my application. I would never go more than 10k though. I forgot to add thats it's almost all highway miles. Over 180K miles and going strong.
Here are a couple links:
http://web.archive.org/web/201010242...es/mobil1.html
http://www.dtsc.ca.gov/TechnologyDev...il-Filters.cfm
#41
Sorry. Stupid was sort of a heavy word. I didn't mean for that to be offensive in any way.
I think contextually it came across wrong. I meant more along the lines of me doing an oil change every 10,000 miles, considering I daily drive my car, would be stupid for me to risk. Just in my personal opinion/preference.
#42
#43
on
Dam it though I have been using Fram for a long time. I guess I am lucky to not have any issues. I just switch to Bosch though with yesterdays oil change.
#44
LOL there is NOTHING wrong with the way Frams are constructed, they are just overpriced for the OCOD variant. Has anyone ever had FIRST HAND experience using them?
I just picked up a Fram Ultra and have used OEM filters in the past for my car, OEM for the wife's car. I've never had an issue with OEM either.
http://www.fram.com/enca/products/oi...tra_oil_filter
Fram is perfectly fine, they had a few shitty runs decades ago (think 30 or so years) and like any business re-engineer, redevelop, and retest their filters. I wouldn't compare a '12 CTS-V to an '82 Cimarron.
#45
http://www.youtube.com/watch?v=cttLaWepdL0
Most OEM oil filters will be Bosch, Wix, or some other familiar brand.
http://minimopar.knizefamily.net/oil...reference.html
