2006 RWD Lower Rear control arm removal
Can anyone please help me by explaining the trick to unscrewing the nut which attaches the lower ball joint on the rear lower control arm. After removing the split pin the bolt just rotates with the ball joint and won't unthread. I've tried an electric impact wrench but no joy. Is there a trick to it, or a tool? How do the pros do it? I've searched all the threads but not much direct help.
Thank you.
Michigan.
Thank you.
Michigan.
My advice is to add some kind of load to the part. If it's unbolted from both ends, just move it to it's max degree of rotation and that should help with adding tension.
I was lucky when I unbolted mine, it came right off with the impact. Try sticking a crowbar in there or something to help load it. Mabye another member can chime in.
rezendvous420
05-31-2020 01:26 PM
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
