2003 G35 Sedan vibration while driving and noise when turning
Old 08-05-2015, 11:02 AM
MyfistYourFace's Avatar
This issue started 2 days ago...
Well I already know my car is due for an alignment since it has a slight pull and I scheduled that and a state inspection this week, but ended canceling the appointment once I started having weird issues on my daily 110 mile commute 2 days ago.
I'll start off by saying I have all season general tires on my G and that the front right rim is bent, and I had some vibration issues before, but I got it road force balanced, which ironed out the vibration. 2 days ago on my commute home from work I noticed my car was harder to drive. By that I mean steering was stiffer, it did not accelerate as easily, and had a slight vibration at the wheel accompanied by a Woooshing sound from outside (similar to wind noise). I also noticed that when turning into my neighborhood I heard under my car what sounded like an old mattress spring.
Compression rod bushing?
Ball bearings?
Tires need rebalancing?
I'm having a mechanic friend look at it tomorrow, but just wanted to help pinpoint the issue before hand.
Any help would be appreciated, thanks!
Old 08-05-2015, 02:28 PM
Mustang5L5's Avatar
RWD car? First thing i'd do is jack up the front end and spin the wheels and see if any are dragging or making noise while turning.
Old 08-05-2015, 03:24 PM
Yes RWD automatic. Thanks for the response. if the wheels drag what would that mean?
Old 08-05-2015, 05:10 PM
joedaddy1's Avatar
can you lift up the car and shake the wheels?
Can be a lot of things that creak.. could be compression rods, bushing, or maybe even ball joints..
get it up on a lift and pull/push/turn the wheels.. youtube has some thing you can do as a basic check.
Old 08-08-2015, 11:58 AM
Well took it our go to mechanic who also owns a G35 and he said everything under the car was perfect and everything was tight. I got my tires balanced last night and had them swap out the bent rim with the spare. I haven't been on the highway yet to see if the problem is fixed or not. As for the noise while turning, I haven't been able to reproduce the spring noise, I guess our cars are known to make the occasional noise I will get an alignment done next week and see how that goes. The car does have some pull to the right. I believe this started when driving to work, I had to drive half on the road and half in the grass/small curb while turning into my work parking lot since they had the whole road blocked off with construction. So maybe that threw my alignment off even further?
Hasanbaloch
02-29-2024 08:45 PM
Augy
Steering & Suspension
09-08-2015 12:53 AM
tehmoonrulz
07-19-2015 10:44 PM
Chattzx
07-17-2015 11:23 AM
Quick Reply: 2003 G35 Sedan vibration while driving and noise when turning
