What did you do to the G Sedan today?
Old 02-08-2017, 01:14 AM
Akin Manzanares's Avatar
Dude I love it! this is exactly what I'm trying to do with my G I'm in the process of looking for new rims and I wanna either get black plastic dip or a paint job
Originally Posted by Fire0nic3
Ran into an issue where the roof spoiler I just installed kept lifting up on the edge after a few days. I used 3M genuine mounting tape and their adhesion promoter inside my garage at room temperature. Still wouldn't stick.....
Decided to remove the spoiler and repeat the process but also add a bead of JB weld. I taped the **** out of the spoiler to hold it down and sat some stuff on it over night. ALL GOOD NOW!
Also admiring how nice the roof spoiler complements the duckbill trunk!
  #482
Old 02-08-2017, 02:26 AM
Mr. Brooks's Avatar
Paint job
  #483
Old 02-08-2017, 11:09 AM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
Originally Posted by Scottwax
Swapped brake pads. The ones on the car were getting there in terms of wear and they dust like a ****.
New lower control arms looking sexy...
What's up me! Also doing this right now lol.
  #484
Old 02-08-2017, 11:00 PM
Swaglife81's Avatar
What pads did you go with? I want something with a good bite, quiet, better than stock for a daily driver.
Why did you replace the lower control arms? Bushings I guess but you still had to bang out those ball joints and replace them right?
  #485
Old 02-09-2017, 06:28 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
No ball joints to bang out on the LCA's. Simply remove the shock arm and ball joint then unbolt both ends of the arm. It's a really simple repair if your **** isn't all corroded to hell. The compression rods sit on a ball joint that probably should be replaced if you have a high mileage car. I run the Megan Racing roll center adjusters which are ball joints that help keep the suspension geometry correct in lowered cars. I've had them on for about 40K miles and they still work great and have held up well.
  #486
Old 02-09-2017, 06:06 PM
Tire rack recommended the Akebono street performance ceramic pads to me. I asked 1000x if it would bite had when cold, and the rep from T-Rack insisted it would!
  #487
Old 02-09-2017, 06:15 PM
TheIronYuppy's Avatar
yup I have those pads on my BBK and they really bite in the cold. It's unusually cold here right now and I really noticed the difference.
  #488
Old 02-09-2017, 06:52 PM
Blue Dream's Avatar
Flashed my Osiris tune onto my Cipher and shipping it out to EPiK. Girlfriend won't know the difference and I'm glad it's going to someone who will appreciate it.
  #489
Old 02-09-2017, 10:46 PM
BradMD_96's Avatar
I had the LCA's done. When I had the a/c repaired last summer, the shop said I'd need to replace the control arm and compression rod (radial arm is what he called it) bushings in the near future. Kind of forgot about it since the car was driving fine. But over the last few weeks, I noticed it dog tracking over rough roads and the steering wheel canted a bit to the left while going straight. Dropped it off this morning, turned out the compression rod bushings were fine, just needed to change the LCA's on both side. Ended up being about $200 less than the original estimate! Car tracks so much better now. I guess as it slowly deteriorates you don't really notice until it gets bad.
What exactly do you mean by dog tracking? I have some inner edge cupped wear on my front right tire - can't be toe because both sides would wear that way and chamber is natural from the drop and again should be pretty equal side to side. I even swapped front wheels and not so long later the front right (originally left) developed the same inner edge cupped wear.
So I'm just wondering what you mean by dog tracking because I find my G is a bit darty and tends to follow the ruts in the road or pull on rough roads. But up until reading your post I put it all down to the wide 255 tires up front....Now I'm wondering (if dog tracking is darty behaviour) then maybe my LCA bushings are bad too - on the one side.
  #490
Old 02-09-2017, 11:00 PM
A bad control arm bushing may be diagnosed by looking at the bushing. Notice the crack in the rubber? It's currently being pressed out to install a new one.
BradMD_96 (02-10-2017)
  #491
Old 02-09-2017, 11:49 PM
G2B35AGN's Avatar
Today I drove my sedanX over a curb. Well, actually it was a chunk of curb. Now you dropanatics may think the AWD sits high. It does not sit high enough. My G has the ability to shave concrete.
It seems clear to me that a construction vehicle for a bridge replacement project pulled off the median and dislodged/broke away the sloped curbing. All I could do as I headed onto the flyover ramp boxed in by traffic was take it head on. Horrible clumping/scraping/grinding noises almost obscured my cries of "oh shizzle" as I tried to halt the destruction with my brake pedal.
Construction foreman and I were able to back the car off the chunk. Plastic underpan is chewed up of course. Not knowing what else might be chewed up I used the Infiniti Elite warranty to have it towed to the dealer for inspection and assessment. Hopefully they will report tomorrow.
Now the fun of making a claim ensues.
  #492
Old 02-09-2017, 11:52 PM
Oh man. Good luck.
  #493
G2B35AGN's Avatar
BTW the white dashed line is not roadway paint striping. It is my G laying down concrete shavings.
  #494
Old 02-10-2017, 12:31 AM
Yep, get that checked out. Since it happened right outside the construction site you might get lucky and they'll pay for any damages. Make sure you give everything the fine-tooth-comb treatment before you sign off on anything.
Your under-shroud did what it was supposed to do. I was going to say at least you can get yourself a nice new alloy one, but I don't think any of them fit the X.
It could have been worse - kind of a gross story but I know someone (a cop) who found a human forearm jammed in the rear suspension of his patrol car.
  #495
Old 02-10-2017, 12:33 AM
noticed condensation in one of my newly-reassembled headlights.
I guess I didn't seal it properly. Looking forward to spending all of Saturday removing it, splitting it, drying it out, re-sealing it, and re-installing it. Grrrr.
Quick Reply: What did you do to the G Sedan today?
