HELP! Check engine light Code P0462
Old 05-07-2016, 01:03 PM
Fire0nic3's Avatar
Hey guys
My cars check engine light came on. I got the code read and its P0462 (Fuel Level Sensor Circuit Low Signal)
I noticed it came on after I filled up the gas tank the other day. Also my fuel level gauge reading always shows full even when there is less than 1/4 of gas left.
So I pulled out both fuel sending units and cleaned the graph looking pads for the fuel level with QTips and rubbing alcohol.
I drive around again and no light. Then I go to fill up again yesterday and the check engine light came back on with the same code.
Any thoughts or ideas what I should do next? I was going to replacing the sending units but there is 2 of them so I dont know which one. I also heard members replacing them on here and still had the issue. I just dont wantto start throwing parts at this car if it doesnt fix it
Old 05-07-2016, 11:56 PM
Fire0nic3's Avatar
Well i figured it out.
I used a multimeter and tested out the fuel sending units. As per the fsm
FULL: 4 ohms
EMPTY: 45 ohms
My tank is completely full. Im getting 4 ohms on the driverside and only 1 ohm on the passenger side.
Guess it is the sending unit. I ordered one and I am hoping for the best.
Old 06-14-2016, 12:14 AM
sindaddy's Avatar
Any update? i am having the same problem.
jbmw002
11-28-2016 10:57 AM
edwinisdumb15
SOCAL Meetings & Events
09-02-2016 03:31 PM
Jiggs1219
02-25-2016 08:30 AM
frodos_4door
02-20-2016 01:08 PM
08STLX
02-11-2016 09:57 AM
Quick Reply: HELP! Check engine light Code P0462
