Fluid leak just inside driver side tire - G35Driver
Show Your Support Become A Premier Member
Thread Tools Search this Thread Rate Thread
Old 02-14-2017, 12:33 PM
Noticed fluid on garage floor just inside the drivers side tire. Mechanic says rack and pinion needs to be replaced. Parts and labor $700. Car has 125000 miles. 2003 G35 Sedan. Still runs great. Is this a part that usually goes around this mileage?
Old 02-14-2017, 12:36 PM
coffeysm's Avatar
They can on some cars. My Audi has had a leaking rack and pinion for a very long time. It's usually the seals behind the inner tie rods that start leaking. You might be able to do it yourself, I know there is a video somewhere of a member here doing one.
Old 02-14-2017, 01:16 PM
Urbanengineer's Avatar
I'm pretty sure mine is leaking too :/.
Old 02-17-2017, 01:21 PM
Mine's leaking too. :/ my shop quoted $600 something just for the part but honestly I plan to leave it as is for awhile. I always check the power steering fluid every 2 weeks or so. I noticed it goes down maybe a millimeter every month or 2.
Old 02-17-2017, 03:16 PM
coffeysm's Avatar
You can buy some remans from rackdocter.net and I've heard they do an awesome job. For the G's they are about 170 bucks not including the core charge. Might have a few hundred bucks in labor, I need to do the r/p on my Audi. I might try rebuilding it for like 50 bucks, but I could get a rebuilt one from that site for about 270.
Old 02-17-2017, 11:50 PM
Thank you coffey! This helps so much. Your a life saver
Old 02-18-2017, 12:34 AM
Mine leaks too. But the odd thing is the leak has been going on for 4 or 5 years and the fluid level has not gone down.
However, i have to keep wiping up fluid from the steering rack and it comes back. Especially around the boot area.
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2002 - 2008, G35DRIVER.COM All Rights Reserved.
