Aftermarket bushings for the AWD
I'm still looking to replace some parts on my car. Anyone install aftermarket lower control arm bushings on the X model? I see again Nissan/infinti does not offer a bushing but the whole arm. I see companies offering them for coupes and rwd sedans but didn't see any for ours.
I read the energy ones will work with some finessing so if anyone's installed them did they work?
Here are the parts you're needing, most likely. https://g35driver.com/forums/g35-sed...trol-arms.html
So, this thread is really about replacement parts for the AWD front end suspension, which is a PITA to deal with. There's not a lot of information. I went through this same gauntlet several weeks back, and even posted a thread as well. In short, I found a manufacturer who supplies both the compression rods and the lower control arm (forward) for the 03-06 G35X, with all OEM-style bushings and joints in place. Best part is that all four items only cost a little over $300.
Us AWD drivers need to help each other out. For anyone here looking for the answer, check my first post in this thread (https://g35driver.com/forums/g35-sed...trol-arms.html) from a few months ago. The four parts linked in my OP were ordered, installed by me (in addition to new struts), and work flawlessy. My 183K mile 2006 X is now very smooth and quiet up to at least 100 mph.
EDIT: The link provided in my post from the other thread will likely lead you to CARID.COM, and to a page which says "out of stock". Just copy the part number and do a Google on those part numbers, and somebody else will have them. Also, O'Reilly's now sells parts for the AWD suspension, at a a 50% premium to the CARID.COM prices you'll see on those links form the other post. I think their part numbers even align with Mevotech's, although O'Reilly's has branded them "Import Direct" or some crap like that. I think they're identical to the Mevotech parts, anyway.
I'm replacing bushings in the front lower control arms, upper control arm and compression rods this weekend. Whiteline all around. From the research I've done, all bushings are compatable between RWD and AWD except for the front strut mount (outer lower control arm). I believe the metal bolt sleeve is just slightly too small for the bolt to fit through, but the bushing itself should fit. I plan to either drill out the bushing and use the OEM bolt sleeve or drill out the Whiteline sleeve to fit the bolt. I will update once complete.
I'm also replacing front struts, strut mounts, inner and outer tie rods, rubber brake lines, hubs, bearings, rotors, pads and tires. Hoping the old X will feel like new next week.
Update
Danielek
05-01-2022 01:28 PM
