DIY 2003/2004 G35 Sedan rattle exorcism - Page 8 - G35Driver
Show Your Support Become A Premier Member
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average.
  #106
Old 03-05-2012, 05:41 AM
Wow, Great Read! I have two areas I can't get rid of. One is my driver seat squeaks intermittently sounds like back left wide squeaks. I have lobed the tracks, and tightened bolts. if I wiggle in the seat, or when I push in clutch (putting pressure on back of seat) it squeaks. Weird part is, if I raise the seat, it gets a lot less noisy?
How do I remove the decorative plastic piece on the side of the seat? I think if I get that off i can get to underside of seat and lube the crap out of something?
I also have squeaks and rattles in sunroof. I think on is loose bolts, but i don't want to drop headliner to fix (is that hard?) but the other is squeaks where rubber seal meets paint of the body when sunroof closed. when body of car flexes over turns, I hear rubbing sound. Should I use silicone spray? Only on rubber not on paint right?
  #107
Old 05-25-2013, 02:14 PM
I had the squeak that sounded like a strut coming from behind the driver side in the decklid area. Pulled the velcro off the seatback, pulled the foam forward from the seatback/x brace and tightened the top bolts on the back seat x-brace, this resolved the issue.
  #108
Old 05-25-2013, 02:47 PM
Quote:
I did this but i still have a squeak back there.
  #109
Old 05-25-2013, 02:48 PM
One of the braces may be cracked. Mine was the bolt that holds the seat to the floor. I put a lil lube on them and tighten it.
  #110
Old 02-24-2014, 09:20 PM
Stupid question but where did you get the felt? Craft store? Was it sticky backed or did you glue it?
  #111
Old 02-25-2014, 05:05 AM
Yes craft store
Thread Thread Starter Forum Replies Last Post
Car Wrap Vinyl - DIY 5ft x 50ft Roll - Matte Colors & Carbon Fiber Tolboothwilley™ Exterior-Vendor 6 07-28-2016 12:42 AM
FS[Canada]: G35 OEM Style Lip Spoiler netcbc Exterior - Body Parts CDN 2 08-21-2015 09:50 AM
G35X 2005 AT 2 questions about suspension and brakes kinetek Brakes & Suspension 9 08-03-2015 04:25 PM
FS: G35 coupe front splash guards in black obsidian color laksjd84 Exterior - Body Parts 1 07-24-2015 05:12 PM
Tags
2003, 2004, console, creaks, deck, door, dynamat, fix, g35, interior, panel, rattle, rattles, rattling, rear, reduce, remove, sedan, shifter
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
