MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Sedan V36 2007- 08
New! Use your Facebook to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 02-02-2007, 02:28 PM
Diagnostic Mode
Looking at service manual. For what it's worth..diagnostic mode in Nav unit is initiated by doing the following:
"Press the BACK switch and the "UP switch of the 8 direction switches" within 10 seconds after turning the ignition switch from OFF to ACC and hold them for 3 seconds or more. The buzzer sounds, all indicators of the preset switch illuminate and the self-diagnosis mode starts"
__________________
'07 G35X @ 33K miles
Old 02-02-2007, 02:31 PM
Radio diagnostics mode is as follows:
-Start engine
-Turn audio system off
-While pushing the "Setting" button turn the volume control dial clockwise or counterclockwise for 40 clicks or more. Then self diagnosis mode is started a short beep will be heard.
__________________
Old 02-02-2007, 02:37 PM
Here are some tests: Display diagnositcs, vehicle signals, speaker test, climate control, Navigation (steering angle/speed calibration/XM SAT status), error history, Vehicle CAN diagnosis, AV COMM Diagnosis, Handsfree phone, Camera (looks like you can modify lines), Bluetooth (passkey and name can be changed), SAT, history deletion..etc.
__________________
Old 02-02-2007, 02:43 PM
If nothing else you can change the Device name and Passkey on the car.
__________________
Old 02-02-2007, 02:55 PM
Cool stuff! These things are like "easter eggs" in DVD's.
Should this be a "sticky"?
__________________
'07 G35x - Blue Slate/Rosewood - Prem, Nav, Tech
Old 02-02-2007, 03:05 PM
Garnet Canuck's Avatar
Traveling Administrator
2007 Infiniti G35
Send a message via AIM to Garnet Canuck Send a message via MSN to Garnet Canuck
Would you guys find it beneficial if I stickied this?
__________________
2007 G35 Sport Garnet Ember Premium|Navi|3M 35% Tint|Bat's GTR Headlight Overlays
2005 New Formula Red S2000 -
Old 02-02-2007, 03:23 PM
terrycs's Avatar
SPONSOR
Quote:
Nah .. just sticky up the service manuals!
__________________
http://www.activetechdesigns.com
for Intelligent Key and LCD Covers
Old 02-02-2007, 03:32 PM
Pulling CEL codes:
HOW TO SET DIAGNOSTIC TEST MODE II (SELF-DIAGNOSTIC RESULTS)
1. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
2. Repeat the following procedure quickly five times within 5 seconds.
- Fully depress the accelerator pedal.
- Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MIL starts
blinking.
NOTE:
Do not release the accelerator pedal for 10 seconds if MIL may start blinking on the halfway of this
10 seconds. This blinking is displaying SRT status and is continued for another 10 seconds.
4. Fully release the accelerator pedal.
ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
NOTE:
Wait until the same DTC (or 1st trip DTC) appears to confirm all DTCs certainly.
HOW TO ERASE DIAGNOSTIC TEST MODE II (SELF-DIAGNOSTIC RESULTS)
1. Set ECM in Diagnostic Test Mode II (Self-diagnostic results). Refer to “How to Set Diagnostic Test Mode II
(Self-diagnostic Results)”.
2. Fully depress the accelerator pedal and keep it for more than 10 seconds.
The emission-related diagnostic information has been erased from the backup memory in the ECM.
3. Fully release the accelerator pedal, and confirm the DTC 0000 is displayed. PBIB0092E
__________________
Old 02-02-2007, 03:39 PM
AUTO ACTIVE TEST
Description
In auto active test mode, the IPDM E/R sends a drive signal to the following systems to check their operation.
• Oil pressure warning lamp
• Front wiper (LO, HI)
• Parking lamps
• License plate lamps
• Side maker lamps
• Tail lamps
• Front fog lamps
• Headlamps (LO, HI)
• A/C compressor (magnet clutch)
• Cooling fan (cooling fan control module)
Operation Procedure
1. Close the hood and lift the wiper arms from the windshield. (Prevent windshield damage due to wiper
operation)
NOTE:
When auto active test is performed with hood opened, sprinkle water on windshield beforehand.
2. Turn ignition switch OFF.
3. Turn the ignition switch ON, and within 20 seconds, press the driver door switch 10 times. Then turn the
CAUTION:
Close passenger door.
4. Turn the ignition switch ON within 10 seconds. After that the horn sounds once and the auto active test
starts.
5. The oil pressure warning lamp starts blinking when the auto active test starts.
6. After a series of the following operations is repeated 3 times, auto active test is completed.
NOTE:
When auto active test mode has to be cancelled halfway through test, turn ignition switch OFF.
__________________
Old 02-02-2007, 04:01 PM
Cruise Control Diagnostics. (ICC)
ON BOARD SELF-DIAGNOSIS OPERATION PROCEDURE
1. Turn ignition switch OFF.
2. Start engine.
3. From 5 seconds through 15 seconds after start engine, press
RESUME/ACCELERATE switch 5 times, and SET/COAST
switch 5 times.
NOTE:
• Never turn the MAIN switch ON.
• When operation above is not completed from 5 seconds
through 15 seconds, start again from above go to 1.
4. When the on board self-diagnosis starts up, the ICC system display shows DTC No. (1) at the set vehicle
speed indicator. Refer to CCS-91, "DTC Index".
NOTE:
• DTC will disappear after 5 minutes.
• When more than one malfunction is detected, a maximum of 3 code numbers can be stored; the latest malfunction will be displayed first.
__________________
Old 02-04-2007, 06:26 PM
Instrument Panel
Diagnosis Description
SELF-DIAGNOSIS MODE
• Information display LCD segment operation can be checked in self-diagnosis mode.
• Meters/gauges can be checked in self-diagnosis mode.
OPERATION PROCEDURE
1. Turn ignition switch ON, and switch the trip meter to “trip A” or “trip B”.
NOTE:
If the diagnosis function is activated with “trip A” displayed, the mileage on “trip A” is reset to “0000.0”.
(The same way for “trip B”.)
3. While pressing the trip A/B reset switch (1), turn ignition switch
ON again.
4. Make sure that the trip meter displays “0000.0”.
5. Press the trip A/B reset switch at least 3 times. (Within 7 sec-
onds after the ignition switch is turned ON.)
6. The unified meter control unit is turned to self-diagnosis mode.
• Displays "888888" and "8888.8" in the information display LCD
(1) for approximately 5 seconds and then blinks the segment
dots of the information display LCD alternately.
• Water temperature gauge and fuel gauge return to zero, and
at the same time.
7. Each meter activates during pressing trip A/B reset switch.
__________________
Old 02-07-2007, 12:56 AM
Thumbs up
Sure!
__________________
2007 G35S 6 speed , TECH, NAV, PRE, spoiler, H&R springs, platinum graphite ; 1998 Subaru 2.5RS coupe w/ JDM STI ver. 8 EJ207, 6-speed
Old 02-09-2007, 10:20 PM
A Consult III setting for the seat slide during exit.
SEAT SLIDE VOLUME SET The amount of seat sliding for entry/exit assist can be selected from 3 items.
40 mm
80 mm
150 mm
[EDIT]
A few more:
PW DOWN SET
Unlock button pressing time on Intelligent Key button can be selected from the following with this
mode.
• 3 sec.
• 5 sec.
• OFF: Non-operation
TRUNK OPEN DELAY
Trunk button pressing time on Intelligent Key button can be selected from the following with this
mode.
• 0.5 sec.
• 1.5 sec.
ROOM LAMP TIMER SET
Sets the interior room lamp ON time. (Timer operating time)
MODE 3* 15 sec.
MODE 4 30 sec.
SET I/L D-UNLCK INTCON ON* With the interior room lamp timer function
OFF Without the interior room lamp timer function
ROOM LAMP ON TIME SET
MODE 1 0.5 sec.
Sets the interior room lamp gradual brightening time.
MODE 2* 1 sec.
MODE 3 2 sec.
MODE 4 3 sec.
MODE 5 0 sec.
ROOM LAMP OFF TIME SET
MODE 1 0.5 sec.
Sets the interior room lamp gradual dimming time.
MODE 2 1 sec.
MODE 3 2 sec.
MODE 4* 3 sec.
MODE 5 0 sec.
R LAMP TIMER LOGIC SET
ON* Interior room lamp timer activates with synchronizing all doors.
OFF Interior room lamp timer activates with synchronizing the driver door
only.
ILL DELAY SET
MODE 1* 45 sec.
Sets delay timer function timer operation time.
(All doors closed)
MODE 2 Without the func-
tion
MODE 3 30 sec.
MODE 4 60 sec.
MODE 5 90 sec.
MODE 6 120 sec.
MODE 7 150 sec.
MODE 8 180 sec.
__________________
Old 02-09-2007, 10:57 PM
i love this stuff! what else can i do? how about rolling the windows UP with the fob?
__________________
2007 G35 Sedan: Black Obsidian on Graphite Leather/ Aluminium, Sport, Premium, Navigation, Technology, cargo net, and G35 factory spoiler (until the dealer removes it)
Old 02-09-2007, 11:01 PM
Still looking for windows up. :-)
EDIT: Unfortunately nothing on remote window up. Closest method would be the key cylinder option already listed in the owners manual.
__________________
Tags
access, diagnostic, g37, infiniti, mode, navigation
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive -
Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
