Scratches in the interior
Old 02-02-2010, 04:03 PM
frybecker's Avatar
I had my driver side door panel and the steering wheel replaced all under warranty. My dealer (Montclair) in socal was very cooperative.
  #47
Old 02-06-2010, 01:30 AM
pinkii's Avatar
Now my alignment is messed up from the new steering wheel and have to get a new cover for it... mine is loose now.
  #48
Old 02-08-2010, 10:15 PM
_RR_'s Avatar
hmmm...i just bought my 07 used and the driver's side panel has a few scratches. I'm gonna call my dealer and try to get them all replaced. Or at least the drivers side.
  #49
Old 02-09-2010, 10:41 AM
NFSP G35's Avatar
? = 2B || !2B
Ok, so every once in a while, I click the V36 section by accident
I don't know if this helps you guys or not, but here's how I solved a similar problem on my V35
https://g35driver.com/forums/body-in...pictorial.html
  #50
Old 02-09-2010, 10:49 PM
PursuitofG's Avatar
knowing my luck i'm going to have a hard time having a dealership replace my scratched steering wheels or door panels
  #51
Old 02-12-2010, 02:34 AM
NationsMostWanted's Avatar
mine too looks bad...im going see if they can give me a new shifter, steering wheel, and sunglasses holder that things rattles like a ****
  #52
Old 02-27-2010, 08:45 AM
JayJay's Avatar
can someone post a copy of there invoice of the dealer changing out there scracted up steering wheel?
  #53
Old 02-27-2010, 10:06 AM
G:Luv's Avatar
On my '07 the plastic top of the armrest on the door, where the window/lock controls are located, has some chipped & scratched areas. I'm going to try to get those replaced along w/the grille. The door handle wells & steering wheel aren't bad at all on mine fortunately.
  #54
Old 03-01-2010, 03:15 PM
bkulleo's Avatar
I have an 08 and I asked about chips and scratches on the door panel last Sat. when I went to a dealer to get oil changed. The service manager told me that he will check to see if he can replace it under warranty but when he came back he told me that since I have a high mileage(43500 miles), he can't replaced it under warranty. I mentioned that I think the warraty is upto 50000 miles and he sugested me to contact Infinity consummer affair to see if they can help me. Is anybody in Houston get it replaced under warranty? The dealer I went was West Houston Infiniti on I-10.
  #55
Old 03-01-2010, 05:09 PM
lefizzet's Avatar
I thought they replaced the material in the 08 so that it doesn't scratch/peel?
  #56
Old 03-02-2010, 06:04 AM
JayJay's Avatar
mid 08 they changed the material
  #57
Old 03-02-2010, 08:21 AM
tg1234's Avatar
^^^ What he said. They change in 08 somewhere. So 08 early has these.
  #58
Old 03-02-2010, 05:46 PM
PursuitofG's Avatar
Try another dealership. Warranty isn't up until 60k miles or 3 years after purchase date
  #59
Old 03-02-2010, 08:09 PM
G:Luv's Avatar
I do believe it's actually 4 years / 60k miles.
  #60
Old 02-08-2011, 10:56 AM
Shadow5606's Avatar
Does anyone have part numbers for the tougher/newer material they used in 08?
My dealer (Dreyer & Reinbold) refused to replace the door pulls or steering wheel trim. They claimed a previous attempt had been made to touch it up and therefore they couldn't cover it under warranty. I only bought the car last week so I can't confirm or deny.
If I replace these parts on my own I want to make sure I'm not using the same old parts that flake off. Part numbers anyone?
FYI, I have an 07 AT Sedan
Quick Reply: Scratches in the interior
