What are the best performance chips for a G35X?
Old 06-18-2010, 11:40 PM
Tbone8484's Avatar
I was looking up performance chips, but read on some forums that there isn't any performance chips for G35s. I found some online like SLR Performance Chip and X3 Performance Chip with O2 Sensor Control. Hopefully you guys can give me some advice.
Old 06-19-2010, 12:27 AM
tg1234's Avatar
Are you talking about those $2 resistors? Don't waste your money. Get the proper tune.
Old 06-19-2010, 12:32 AM
340tog35's Avatar
anything from frito lays is good But ya man dont do it the cheap way
Old 06-19-2010, 08:35 PM
Tbone8484's Avatar
No, I am talking about these chips which cost $70 or $100.
http://www.engineperformancechip.com/infiniti-performance-chip-infiniti-g35-2003-2008-c-16_362/x3-performance-chip-with-o2-sensor-control-p-6[/URL]
http://slrmotorsports.com/shop/index...t_detail&p=366
Also what does it mean to tune your car and how does it increase the performance?
Old 06-19-2010, 09:42 PM
LakeShore_Slate's Avatar
Those chips are CRAP dont buy that **** you'll just waste your money. If it seems to good to be true it probably is. I've seen them before when I was looking into my tune and ran away as should you.
A 'tune' is basically among other things installing after market parts (i.e. exhaust, intake(s), headers, etc.) and telling your ECU that it can preform at this level now rather than the stock factory setting. Aka re-mapping or flashing. In addition this is how it increases performance.
If your looking to do it the right way its going to be in the $400-$600 range. Good luck, hope I helped or gave you any insight.
Old 06-19-2010, 09:54 PM
O HELLA OEM's Avatar
not again
Old 06-20-2010, 06:18 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Old 06-20-2010, 08:21 PM
Tbone8484's Avatar
Thanks for the help, I figured those chips were too good to be true especially when it said it would increase hp by 55 for only $70, bastards. I will check out tuning
Old 06-21-2010, 03:53 PM
Q8y_drifter's Avatar
start here
www.cobbtuning.com
but you'll eventually end up here anyway...
www.uprev.com
Old 06-21-2010, 04:51 PM
suby01's Avatar
this guy has sum
cmesidewayz
09-29-2015 09:28 PM
DRG35R
09-16-2015 05:33 AM
vstring
09-11-2015 02:50 PM
kevintandmd
09-03-2015 06:41 PM
Quick Reply: What are the best performance chips for a G35X?
