A/T grounding point? - G35Driver
Show Your Support Become A Premier Member
Thread Tools Search this Thread Rate Thread
Old 08-23-2011, 11:30 AM
I am thinking to add a ground cable to the automatic transmission but don't know where the best point to connect the A/T to the chassis. Anyone who has successfully done it, please share it here. Pictures would be helpful.
Thanks,
Old 08-23-2011, 01:24 PM
i have not done this, so obviously i don't have pictures, but i want to believe if you get underneath the car and pick any mounting bolt or location of an existing equipment ground that you should be ok.
this may be a good idea, i'd be curious to see if this helps anything. when i had my taurus SHO, adding a ground cable helped smooth out the overall operation but that could also have been the placebo effect.
Old 08-23-2011, 04:17 PM
kool_yaar's Avatar
^ judging from all the ppl who have posted a review of the grounding kits it seems as if it really helps a lot on the ATs, and as for the location you can just read on Black Bettys or other vendors DIY guide on myg37.com and that should tell you the exact point, but like remmy said using the existing point should be easy.
Old 08-23-2011, 05:13 PM
bluedevils95's Avatar
I have to look for the pix.
Old 08-23-2011, 05:17 PM
Old 08-23-2011, 05:19 PM
It's an old pix but it will do
Old 08-23-2011, 05:35 PM
i installed the black betty grounding kit but i thought what you were asking was a transmission ground, which isn't included in the kit. if i recall....
Old 08-23-2011, 06:22 PM
kool_yaar's Avatar
^ i think he includes it now or maybe its the other guy Sean... but that would be an important grounding point if you were to spend this much money on this kit
Old 08-23-2011, 07:25 PM
You dont need to add a cable to the trans, it is grounded by being bolted to the engine and the engine being grounded. Get the BB kit and install as directed, it works
Old 08-23-2011, 08:10 PM
Blue, I saw your picture all over already. lol
What I am asking for is the connecting point on the AT assembly and possibly the nearest grounding point to the chassis.
I already knew the grounding points on the engine bay and on the way ordering the custom cables.
Old 08-23-2011, 09:35 PM
GXXXV X's Avatar
i have an X and i posted pix a few months ago of where i attached the wire to the tranny..i will try to search for it
Old 08-24-2011, 01:06 AM
On the pass side of the trans towards the front there is a bracket held on by 1 bolt. Remove the bolt and attach the wire there, then the wire runs up to the top back of the engine and attaches to the the back of the intake manifold in the same spot 2 other engine bay grounding wires are attached.
That is for the coupe btw. I don't know how differ the X is.
Old 09-04-2011, 06:39 PM
Installed a kit from SxExCx. Fairly straightforward, not too difficult. I dropped the AT ground down from the passenger side TB and attached to a bolt below the driveshaft. It looked like a solid connection. I used zip tie to metal tube/line in the picture foreground and at the top outboard of the TB to keep the wire away from the exhaust.
A/T grounding point?-08-g35x-grount.jpg
Old 09-05-2011, 02:44 AM
Thank you for your picture.
I used 2 4AWG cables for extra grounding. I installed one from the battery and the second from the engine block. Both ends are screwed on the grounding point below the factory information plate on the passenger side.
Results: noticeable smoother shifts and louder sound at the same volume. I guarantee this is not a placebo effect since my girl noticed this too.
Old 09-06-2011, 12:46 AM
There's no such thing as "extra" grounding, it's either properly grounded or it isn't, and one cable properly installed is sufficient. You don't need two.
Thread Thread Starter Forum Replies Last Post
FS: **G35 Twin Turbo** g.spot G35 Cars 12 05-09-2016 11:54 PM
Bad wheel bearing? Opinions please! (Video+Audio) Marlin84 Wheels & Tires 21 03-02-2016 11:25 AM
Really wanted to stay, but had to let go :(.. prinny The G-Spot 6 11-23-2015 12:07 AM
Engine trouble vamarris Engine, Drivetrain & Forced-Induction 0 09-26-2015 01:56 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright 2002 - 2008, G35DRIVER.COM All Rights Reserved.
