Window one touch up funtion not working?
Old 11-12-2011, 03:11 PM
rinaldi69's Avatar
All the one touch up/down features are working on all windows, but for some reason the one touch up on my drivers window is not working. Is there a way to re-set this or do you think I have a mechanical issue?
I know in my wife's car (Mazda) you can re-program by taking window all the way up and hold the up button, but that trick does not work on the Infinit. Also, did not see anything in the manual either.
Old 11-12-2011, 03:44 PM
surfjax87's Avatar
Open the window all the way. Hold the switch all the way up, continue holding for 15 seconds after it closes.
The following 2 users liked this post by surfjax87:
G3065 (11-14-2011), rinaldi69 (11-13-2011)
Old 11-14-2011, 08:11 AM
gtbigup01's Avatar
Hope you got it to work. If not, manually press the button to let window down more than half way, then click auto-up and hold for more than 5 secs. This is from my 07 owners manual + I just had to do it Saturday since I replaced my car battery and none of my windows would do auto-up after the battery was replaced. Reset procedure worked like a charm. BTW it is in your book under power windows.
Old 11-14-2011, 11:28 AM
bluedevils95's Avatar
Have you tried it yet?
Old 11-14-2011, 12:13 PM
salvador312's Avatar
This question is getting old!!!
Old 11-14-2011, 12:30 PM
vqsmile's Avatar
yuh think?
Old 11-14-2011, 10:15 PM
ORRRR's Avatar
I also have the same issue with my driver side window. One touch up/down works for all windows except for driver side.
I tried the reset procedures from this thread but they didn't work.
Any other suggestions?
Old 11-14-2011, 10:31 PM
vqsmile's Avatar
***SIGH***
http://lmgtfy.com/?q=resetting+one+touch+window+g35
Try again
Old 11-15-2011, 10:43 PM
infinitidude's Avatar
ok guys open all the windows,once they are open manual up and when it gets to the fully closed position continue holding in maual up for more than 5 seconds
this is the proper procedure from infiniti
The following 2 users liked this post by infinitidude:
BobbleHead (04-29-2014), Gpowerr (04-19-2014)
Old 11-16-2011, 10:42 PM
ORRRR's Avatar
I tried that method and it didnt work for my driver side window. Do I have to press all 4 windows down then up at the same time? Does the car need to be ACC or ON?
Old 11-17-2011, 10:39 AM
gtbigup01's Avatar
Maybe you guys need to do it the correct way. You open the window more than half but not all the way down. The procedure is probably slightly different for every year car. See my above post from my 2007 owners manual under "Power Windows"
1 window at a time.
Old 11-18-2011, 03:15 PM
ORRRR's Avatar
1 window at a time.
That method did not work for me, and I have a 2007.
I also tried the "holding window down then holding window up" method, but it would just get stuck in the down position and not respond until I turn off the car and back on.
Old 11-18-2011, 07:47 PM
If you having problems still, i would go see the dealers.
Old 11-19-2011, 12:18 AM
newt117's Avatar
Thanks I just did fixed my 4 windows. I have been frustrated by it.
Old 04-19-2014, 06:05 PM
Gpowerr's Avatar
this worked great on my 08
mike730
01-12-2018 04:25 PM
Gip
08-24-2015 05:31 PM
Jussaku
Interior
07-29-2015 04:13 PM
will091195
07-27-2015 09:19 PM
apintojr
07-23-2015 10:52 AM
Quick Reply: Window one touch up funtion not working?
