Long crank / hard start issue 07
Just got my G a few weeks ago, love the car to death. But about every other time i start it, it cranks for like 2 seconds... doesn't sound like much but i'm sure you guys know what i mean. It just cranks for a while before it catches.. Runs fine otherwise. Filters are all changed, i put good gas in it, if i turn the ignition on for a while first, or the car had been running, it seems to do it less... Things i should worry about? I'm just used to most cars catching on the second turn of the motor or so
^^ I've seen similar to this in other (non-Nissan) makes, except it was the crank position sensor. Apparently, many auto makers set their cars up to activate the fuel pump and/or fire the injectors ONLY in the presence of a valid crank rotation signal. I think I read that this is partially a failsafe so that, in case of an accident, the fuel doesn't continue running under pressure. But, in this type of scenario, if the crank signal is glitching on the first few rotations, then the fuel will be delayed until it reads properly, and thereby results in a long cranking cycle before the engine starts.
I just bought the car. Didn't seem to do it when i was test driving it, but who knows. It starts every time, just cranks longer than i think it should. About once every 3 or 4 starts it works like it should, starts right up, no issues, but usually has a raised idle for about 20 seconds after a good start
the car has 55k on it, no mods, haven't done anything to the car but it has fresh oil, and all filters are new.
it's an 07 x with an auto trans... seems to run great besides that, gas mileage is kinda shitty, but that's coming from a smaller cars and i think all of these cars get pretty poor mileage...
I'm probably going to end up doing some intake cleaner crap and a tune up here in a bit, though, with the way plugs and cars are these days, i wouldn't have expected that i would need to do this on a car with these miles.
Since battery is such an issue with these cars, I would definitely check again. How old is the battery. If more than 3 years old, I would definitely swap it out. I usually do not recommend swapping out parts that *could* be causing the problem but the battery needs to be strong to start modern cars well. My dad's RX300 recently had started taking a long time to cranking to start. His battery was 3 1/2 years old and I recommend he change it. Sure enough, starts up quick now.
http://www.infinitiscene.com/forum/t...start-problems
http://www.infinitiscene.com/forum/t...-problem/page3
I guess fx owners have the same issue and have replaced the "ac amplifier"?
