DIY Replacing Steering Wheel Bezel v36
Hello G community I just got my car July 20th as a B-Day present and decided to already start modding it!
I tried looking up a DIY for this on both myg37 and this forum with no luck so I decided to make one.
Im pretty sure im not the only one with this problem.
Does your steering wheel look like this
Well I am going to show how to fix it
So tools you are going to need is a flat head, 9mm socket, 19mm socket, and a T30 torq bit.
Obviously the new Bezel which you can order basically any infiniti dealer or online. I got my mine from Circle Infinti ebay store for $26 shipped.
So lets get this started first most important step DISCONNECT the negative side BATTERY
after we move to the inside where you will remove two pop out circle clips on either side on the wheel
once you have done this gently remove the airbag and disconnect the orange and yellow clips with a small flat head
then your air bag is off
Next is removing the ground and control switches. Then you can remove the 19mm center nut and take your steering wheel off!
After you will see the back plastic is still it is 4 clips you can use a flat head to unclip and it comes of like this
Then its about 8 screws holding the bezel
And your done just use some reverse steps and your new bezel is on
Hope this helped you guys out! Feel free to ask me any questions
The following 11 users liked this post by pcfiii:
dale749 (08-23-2014),
g35xdriver (09-01-2013),
Gig103 (11-11-2013),
hybridamp (08-13-2014),
Johnny Harris (09-18-2013),
and 6 others liked this post.
Since you went through all that "trouble" to replace a simple bezel, might as well get the paddle shifters installed. No guarantees if your car is pre-wired though.
EDIT: your car is a manual, my bad. If anyone is thinking of this and have an AT without sport package, then paddle shifters could be installed.
