Whining sound from engine bay!?!
Old 03-10-2014, 03:58 AM
Gdupm6's Avatar
This video here is exactly what my car sounds like. I recently did an oil change on the car, but did NOT use full synthetic oil. Could that be the problem? Thanks
Old 03-10-2014, 04:26 PM
Gdupm6's Avatar
bump
Old 03-10-2014, 05:56 PM
staticwhippinit's Avatar
also have a similar problem,
not as noticeable and happens on and off. (usually after being driven for more than 40 min)
I also just got a synthetic oil change. What oil did you use?
Old 03-10-2014, 06:06 PM
Gdupm6's Avatar
mobile 1
Old 03-10-2014, 06:08 PM
Originally Posted by Gdupm6
mobile 1
what weight?
Old 03-10-2014, 06:26 PM
Gdupm6's Avatar
5w30
Old 03-10-2014, 09:18 PM
willdogs's Avatar
Air Conditioner Compressor bearings. Common issue on our cars.
Try this, Turn off your climate control and see if the noise changes or stops.
Oh - I noticed mine quieted way down once I changed the Drive belt. Have you changed your Serpentine/drive belt? It needs to be changed every 40-60,000 miles.
Old 03-10-2014, 09:27 PM
Gdupm6's Avatar
I tried turning the climate control off it didnt help. I haven't changed the serpentine/drive belt actually, but i know i need to. Does it make a change in engine bay sound dramatically?
Old 03-10-2014, 11:33 PM
mathnerd88's Avatar
Could be the belt or a bearing the belt rides on that is out of balance, causing a whining noise.
It is similar to a wheel that has a damaged wheel bearing, so it would whine as it rotates. It could be a fan? It sounds like a rotating noise.
Old 03-11-2014, 01:43 PM
Finnkc's Avatar
Sounds like a bearing / belt. Could be a bearing on, water / power steering pump?
Old 03-11-2014, 02:44 PM
cline328's Avatar
I had a whining/squeal sound at idle and acceleration and a new belt took care of it. Worth a shot if it needs to be done anyway
Old 03-11-2014, 09:34 PM
willdogs's Avatar
For me it did. Also you have to change i anyway, if you are past 60,000 miles you should change it, otherwise you risk it snapping/failing on you anyway...not a good thing.
Old 10-09-2014, 01:10 AM
BlackG35Driver's Avatar
I have this exact same issue, that video posted is EXACTLY what it sounds like. It just started a couple days ago... I will look into the belts and see if that is the issue and will post an update.
Old 12-12-2014, 01:46 PM
bd0g36's Avatar
I have that same sound with my '07G coupe. It just started a few days ago. OP, did you ever solve it?
zoop425
03-29-2016 05:51 PM
pigpen infiniti
08-16-2015 09:07 PM
Quick Reply: Whining sound from engine bay!?!
