Turning off traction control
Because not everyone on this board uses their car in the way that you do. Most of us use it as a daily driver to get from A to B. Maybe push it a bit on the highway once in a while.
So for most of us, pushing the VDC button is sufficient for when we want to have a bit of "fun". You are driving to the extremes to the extent most of us will never do, nor do we have a reason to.
Mine turns completely off. I do have a 6mt though but I can do burn outs and drift my sedan at will with no interruption from the traction control. My traction control is pretty mild even when on. The back wheels will spin enough to startle my wife in the rain if she is not ready for it. I wonder if the sport models have a less intrusive TC than non sport models? Food for though....
I played a lot in the snow this winter, and could definitely feel and hear the abs when I had vdc on. When I had it off, my car would spin if I got too out of shape, with absolutely no intrusion from abs.
No it dosent what? If you are referring to the possiblity of a different sensitivity for the VDC then thank you for the input. If however you are suggesting the VDC on MY car does not fully disable then not only are you mistaken but out of line. As as senior SCCA drift program instructor and track day car builder I know how to identify if the vdc is functioning or not.
I just thought of a second possibility. The non sport cars do not have a LSD so when the tires spin there will at times be a drastic difference between the two rear wheels rotational speed. That is most likely triggering the abs to act like a makeshift LSD in an attempt to equalize the wheel speed between drivers and passenger sides. Since sport models have an limited slip the wheel speed will not be different enough to trigger the abs and interrupt the fun.
#30
There's Tc and then there's vdc. I have an 07 6mt sedan and while the vdc button reduces traction control intervention it does not turn it off (For Me). I believe the button disables vdc but it only reduces traction control. Consider yourself lucky if it turns both off completely, I wish I had this option. While I have no desire to do smoky burnouts I wouldn't mind having a little more fun in the snow and rain from time to time.
Regardless of vdc on or off, this car has some serious wheel tramping which is a turn off for breaking traction.
