Pittsburgh ATF Flush
Can't say how much it is. But, it should vary between 60-300 dollars. If they do a drain refill it's cheap. If they do a flush it's a lot more about 12 QTS. The fluid is what usually ends up costing the most at 10 bucks a at min.
Unfortunately, the terms "fluid change" and "flush" are used loosely and often interchangeably, even when they clearly shouldn't. One involves just draining the pan and replacing what was drained, the other potentially involves opening the hydraulic lines and replaces the entirety of the fluid in the tranny.
How much does the dealership there charge? I'm in GA, and I have an 08 with 115k miles. I have done the transmission fluid change at 50k and again at 100k at the dealership for $59.00 each time. I thought that it was a reasonable price at the dealership when I had mine done.
FS[NorEast]: FOR SALE: 2007 G35X (82K miles, Asking $12,000)
heynow
2nd Gen (V36) Sedan
10-28-2015 05:09 PM
