1 year after getting P0011 fixed
It was around a year ago that I got my gaskets replaced. Before my warranty on the repair expires I decided to run a oil test to see how the car is doing. Also, I drove the car with the code for about a year before getting it fixed. Everything is completely normal, I did not replace any time chains or hardware just the gaskets themselves. The results say it's completely normal and within the ball park, the extra silicon is due to the sealant used. Hopefully people with the code can feel a bit better haha
vqsmile (04-17-2015)
Great to know for v36 owners! I don't own one, but this is a great update for the community. Nothing I hate more than having a major issue and being haunted by the idea that its gonna come back. Please keep this updated every 6 months or so for history's/research sake.
yes I'll try to keep it up to date every time I run an oil test. The VQ motors are very well built, I was running about 7psi at idle before the fix and that was driven for an year, given that I did not drive with the code, I kinda learned how to drive it so that the code doesn't show up but nevertheless the pressure was lacking. But even at these conditions the engine ran without a problem and no damages whatsoever. Runs great, sounds great.
Nice result. I meant to send in a sample to Blackstone from my new-to-me 104k mile '07, but forgot to grab a sample before it slowed to a dribble. Whoops. Next time.
Reading about the gasket failure makes me want to check the oil pressure though. If it is low, a ~$1500 repair would suck on a $12k car, but then again, it's a nice $12k car. I probably should have had that checked during my two PPIs. Live and learn, I guess. The good thing is that the only stored error code, according to the dealer, with this car is for the adaptive cruise control (dirty sensor). No p0011, but that doesn't necessarily mean the gaskets are fine, right?
I'm assuming the easiest way to check it is the second method here:
https://g35driver.com/forums/v36-diy...-pressure.html
Ha, yeah, that's not going to happen.
If it blows, it blows. If and when that happens, I'll either take it in to get fixed, or take a swing at it myself. From everything I've gathered, it's not catastrophic, and from what you and others have said and shown with your oil analysis, it doesn't seem to cause any damage other than a rather sizable dent in the old wallet.
[QUOTE=SofaKingAzn;6990291]It was around a year ago that I got my gaskets replaced. Before my warranty on the repair expires I decided to run a oil test to see how the car is doing. Also, I drove the car with the code for about a year before getting it fixed. Everything is completely normal, I did not replace any time chains or hardware just the gaskets themselves. The results say it's completely normal and within the ball park, the extra silicon is due to the sealant used. Hopefully people with the code can feel a bit better haha
20 minutes after buying my 04 g35 with 141,000 on it, p0011 and p0021 came up after seeing my SES light come and scanned it.. I have a warranty so they took it right back.. 3 weeks later they've replace every sensor, both solenoid valves and sensors, timing chain, gaskets, all except the engine control wiring harness.. the light is still on, I drove it and it hesitates so bad when accelerating and is by far the car I bought weeks ago, it also rattles almost like dragging chains at low rpms.. They now found an electrical bad ground and are replacing the engine harness completely.. consider yourself so lucky that you did not have to go thrpugh any of this lol
Received 2,456 Likes
on
Coupe 6MT Premium RAS
His was an entirely different motor (VQ35HR) and his codes are usually caused by a failure of a paper gasket inside the timing chain cover. Your VQ35DE doesn't typically have THIS issue but those codes could be a number of things (looks like they're narrowing that list down). Is the dealer doing this work for you? Normally the dealer is able to find the issue the first time, the FSM has very exact steps for testing everything rather than just replacing every component that "might" be the problem.
