2007 G35 Sport - Front Lower Control Arm Bushings
so it seems that the creaking noise that i've been experiencing is due to my FRONT LOWER CONTROL ARM BUSHINGS.
after greasing them the noise went away - but after the grease wore off, it's back.
the control arms are quite expensive, so i'm trying to avoid replacing them.
does anyone know if i can just replace the bushings? has anyone done this? do you have the part #'s for the just the bushings?
is there a better grease that will last longer?
is there any danger in driving the car as it is? what's the impact of bad bushings on the front lower control arms?
http://www.whitelinesuspensionparts.com/w52991
I'm just now searching this problem - did you get the work done?
Hasanbaloch
02-29-2024 08:45 PM
rezendvous420
05-31-2020 01:26 PM
