Hearing a growling noise coming from the front.
It's my brides car and obvious she doesn't hear anything. A few details.
Its an 07 sedan, tires are getting near the wear bars and being replaced this week, brakes look good, I jacked up the front end and the CV joints looked good and both wheels turned without any unusual sounds.
What am I missing??
Thanks!
What am I missing??
Thanks!
I like to find the issue then finish it off with new tires. New tires mask a lot of noises and if there is an issue you've already began feathering those new tires. Hopefully that was your problem!!!
The tires do not show any signs of feathering, just a little more wear on the inside than the outer edge.
Tire replacement is due to the fact they are almost to the wear bars and my bride ignored the tire sensor light and drove on on when it was way too low! Nothing $500 can't fix.
The vibration in the steering wheel isn't the side to side shake but something that feels like its coming up through the column.
I had a light howling recently that ended up being the tires being worn too close to the belts in one off-center position. It was pretty weird. The tire was really soft in this one position and I think that's what was making the noise. Put new tires on and it was gone.
rezendvous420
05-31-2020 01:26 PM
ScraggleRock
08-11-2015 10:16 PM
