Removing cat heat shields.
For those of you that removed the heat shields from your cats - How did you get the top part out? Did you just hack and cut away at it with a cut-off wheel until it was small enough to fit between the top of the cat and the bottom of the car? The bottom piece literally fell apart in my hands once I started pulling on it but I was not able to just pull out the top half with my hands.
