No lights, cluster and dash.
I've searched for this and can not find anything close to my issue. Everything worked fine yesterday. Got in car this morning started it up, cluster and all dash lights were on. Turned on my head lights and everything is black like I shut the car off. Everything is working as it should. Just no lights, headlights and all worked. I'm sure there is a fuse, and I don't have an owners manual. Can anyone give me the fuse number please?
I will do that. Hope they are. I drove to work at 2am this morning. I know the brake lights, and turn signals were working. Do you know that fuse number or where I could get a list of all the fuses and relays?
Just don't understand why people take their owners manuals out of the car and don't put them back in there when they sell a car. It's a 2 owner car from Alabama only had 80,000 miles. With a clean Carfax. Carfax never showed any issues at all reported.
Yeah the brake lights are on a different fuse. If you take all the trim around the battery up you will find the ipdm/er behind the battery. Once you can access it and get the lid off I believe it is the top left fuse. It may even tell you on the lid which fuse is which. I know the V35 models had the fuse names on the lid. Hope this solves your issue brother.
You can download the Owner Manual for your car here: https://owners.infinitiusa.com/conte...-G35-Sedan.pdf
And if you want the actual Factory Service Manual, you can get that here: http://www.nicoclub.com/FSM/G35/Sedan/2008/
Well all the fuses are labeled. I pulled every fuse, under hood and dash. All were good. Even unhooked battery for well over 30 mins while car cooled some.
2 things though, when I turn the car on, not starting, cluster shows brightness min. Dimmer buttons will not do anything period. With lights on or off.
Second things, again turn car on, not starting. After the few little beeps it does. The service engine soon light flashes 5 slow blinks, then remains on. SES light off when car running.
This is killing me. Can't afford to pay dealer to even look at it right now. Hell barely had it a month.
