Shop charging 2hr labor to replace rotors
Old 06-13-2016, 05:08 PM
youngdip631's Avatar
Im about to go pick up my car from the shop that did my springs recently. I had a little clunking noise by the front passenger wheel after the springs were installed so i figured since its gonna be down there getting checked out i might as well have them do my rotors (that i bought) too. It is $110 an hour for labor. I know the calipers had to have come off easily along with the rotors because i just took them off a year ago to get them powder coated! When i set up the appointment they said it would only be an hour labor. Should i argue with them?
Old 06-14-2016, 12:50 AM
esotericrider's Avatar
argue... rotors are a quick swap. I had two front rotors taken off, turned, and put back on. Cost me 60 for everything and I am in California...
Old 06-16-2016, 09:48 AM
nizzan4u2nv's Avatar
Pulling rotors takes at most 15 mins per side with a jack and basic hand tools.
Old 06-16-2016, 10:48 AM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Two hours isn't unreasonable, removing them is easy, installing the new rotors plus adding the lugs takes time! If your pads aren't new I have those replaced too, may as well start fresh! Do the bed in process when you leave the shop, always a good
Gary
Old 06-19-2016, 07:24 PM
blnewt's Avatar
In your first post you said they were going to charge you an hour labor, did that change???
Old 06-22-2016, 04:07 AM
Rico Suavey's Avatar
argue shouldn't take more than a hour..
Old 06-22-2016, 10:26 AM
coffeysm's Avatar
According to AllDataDIY it's about 1.4 (.4 each front rotor and .3 each rear rotor) hours of billable time. I would find it hard to replace all four rotors in an hour if they were doing it meticulously (like it's their own car).
I've replaced all four of my rotors several times on my own and it always takes a 2-3 hours myself. However, that's because I go through everything methodically. I relubricate all the guide pins, put anti-seize on the rotor hat, anti-size where the brake pads slip into the caliper, etc.. The rears also take the longest for me, since it's hard to get back there. Not counting the times when the rotors become seized and you have to get them off.
If they go off AllData you might be able to argue with them about the billable hours and inspect the work they did first.
J_Burna
06-07-2019 09:46 AM
hoon
03-20-2016 01:31 PM
HRG3N3RAL
03-19-2016 08:07 AM
flhtvtwin
Steering & Suspension
03-16-2016 06:00 PM
Jdmay35x
03-16-2016 03:31 PM
Quick Reply: Shop charging 2hr labor to replace rotors
