VDC off, slip, abs, low tire, brake lights on. help!!!
Hey guys, I'm usually pretty good at troubleshooting things but I don't even know where to start here. So recently I have driven through a big rain storm and to sum it up, the car was rebuilt and I have found the ICC cruise sensor wires cut as they did not replaced the sensor. The rain storm have shorted something and now I have a series of lights on including low tire pressure, brake, abs, vdc off, slip, key, and the master warning light. It used to only take one press of the push start button to turn the car off, now I have to hold it down for a few seconds and even that, it goes to acc and don't completely turn off until I push the button twice more. (One time to go to on and once more to off). It will start normally with clutch held down.The car is 07 sport sedan. I've tried to disconnect the battery to see if it'll reset but it doesn't. Any help is appreciated, thanks.
Car wasn't in a flood. I was driving through heavy rain. It had prior front end damage before I bought the car that was fixed. The car came equipped with laser. The connector that goes to the ICC laser was cut and tapped because they removed the unit. I'm thinking it was just my luck that maybe through the storm, something shorted because all the lights stated came on afterwards. After I had pulled in the garage I stumbled upon that connector with electrical tape peeling off of it behind the grille
